TP LINK 10GBase-SR SFP+ LC Transceiver
Quicklinx: G6XKWS00 Mfr#: TL-SM5110-SR
44 In Stock
£25.81 ex VAT
£30.97 inc VAT
The TL-SM5110-SR is designed to extend transfer distances based on 10 Gbps Ethernet connectivity. It is a 10GBASE-SR high performance 850 nm multi-mode SFP+ transceiver. It supports full duplex, 10G Ethernet connections up to 300 m or 33 m with 50/125 µm or 62.5/125 µm fiber cables respectively.
TP-Link TL-SM5110-SR - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC/UPC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
300 m
JetStream TL-SG3428X, TL-SG3452XP V1
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Hot swappable
IEEE 802.3ae
1 x Ethernet 10GBase-SR - LC/UPC multi-mode female x 2
FCC, MSA SFF-8472
70 °C
10 - 90% (non-condensing)
TP-Link JetStream TL-SG3428X, TL-SG3452XP V1
Brand: TP LINK
