TP LINK 1000M RJ45 to 1000M SFP Slot Supp. MiniGBIC Modules Adapter
Quicklinx: 8970WS00 Mfr#: MC220L
48 In Stock
£15.71 ex VAT
£18.85 inc VAT
The MC220L is a media converter designed to convert 1000Base-SX/LX/LH fiber to 1000Base-T copper media or vice versa. Designed under IEEE802.3ab 1000Base-T and IEEE802.3z 1000Base-SX/LX/LH standards, the MC220L is designed for use with multi-mode/single-mode fiber cable utilizing the SC/LC-Type connector. It works at 850nm on both transmitting and receiving data when adopting multi-mode fiber and 1310nm on both transmitting and receiving data when adopting single-mode.
Other features of this module include the ability to be used as a standalone device (no chassis required) or with TP-Link's 19"system chassis, Auto MDI/MDI-X for TX port, and front panel status LEDs. The MC220L will transmit at extended fiber optic distances utilizing multi-mode fiber up to 0.55 kilometers and 10 kilometers when utilizing single-mode fiber.
TP-Link MC220L - fibre media converter - 1GbE
Fibre media converter - RJ-45 / SFP (mini-GBIC)
External
Cabling Type
1000Base-LX, 1000Base-SX, 1000Base-LH
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm / 1310 nm
1GbE
Max Transfer Distance
10 km
9.5 cm x 7.3 cm x 2.7 cm
P/N: TL-MC1400
External
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm / 1310 nm
10 km
Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode
IEEE 802.3z, IEEE 802.3ab, IEEE 802.3x
Expansion Slots
1 (total) / 1 (free) x SFP (mini-GBIC)
1 x Ethernet 1000Base-T - RJ-45 female
FCC
External power adapter
9.5 cm
7.3 cm
2.7 cm
10 - 90%
P/N: TL-MC1400
Type: Media Converter
Brand: TP LINK
