TP LINK 1000Base-BX WDM Bi-Directional SFP Module LC connector
Quicklinx: 896XWS00 Mfr#: TL-SM321A
TP-Link's TL-SM321A adopts the latest standard 1000Base-BX, transmission over a single strand of fiber, with one different wavelength going in each direction. You can extend the network distance up to 10Km with TP-Link's routers, switches, media converters to provide high speed and stability.
TP-Link TL-SM321A - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-BX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1550 (TX) / 1310 (RX) nm
1GbE
Max Transfer Distance
10 km
P/N: TL-SG3452XP V1
Plug-in module
Wired
Cabling Type
1000Base-BX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
10 km
IEEE 802.3z
1 x Ethernet 1000Base-BX - LC single-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
Plug and Play, FCC
70 °C
10 - 90%
P/N: TL-SG3452XP V1
