TP LINK 10-Port Gigabit PoE+ Switch
Quicklinx: FND9WS00 Mfr#: TL-SG1210P
Type: Gigabit Ethernet
Ports: 10
Data Transfer Rate: 1Gbps
Managed: No
POE: PoE+
£70.62 ex VAT
£84.74 inc VAT
  • 9 10/100/1000Mbps RJ45 ports, 1 Gigabit SFP port
  • With 8 PoE+ ports, transfers data and power on one single cable
  • Working with IEEE 802.3af/at compliant PDs, expands home and office network
  • 802.1p/DSCP QoS enable smooth latency-sensitive traffic
  • High PoE power budget with up to 30W for each PoE port and 63W for all PoE ports
  • Easy to use, with no configuration and installation needed
  • Power over Ethernet
    Port 1-8 of the switch support Power over Ethernet (PoE) function. These PoE ports can automatically detect and supply power with those IEEE 802.3af/at compliant Powered Devices (PDs).
  • Intelligent power management
    When total power consumption excels 63W, the intelligent power management will cut the lower priority port power off to ensure the high priority port's power supply and protect the device from power overload operation.
  • Sturdy metal casing
    Sturdy, compact metal casing, with desktop/wall-mounting design, to meet your needs in any environment. Besides, fanless design ensures quiet operation.
TP-Link TL-SG1210P - switch - 10 ports - unmanaged
Switch - 10 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 1 x 10/100/1000 (uplink) + 1 x Gigabit SFP (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
63 W
Performance
Bandwidth: 20 Gbps
MAC Address Table Size
4K entries
Flow control, IGMP snooping, store and forward, fanless, metal housing, DSCP based QoS
IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
20.9 cm x 12.6 cm x 2.6 cm
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
63 W
Performance
Bandwidth: 20 Gbps
4K entries
8 x 1000Base-T RJ-45 PoE+ , 1 x 1000Base-T RJ-45 uplink , 1 x Gigabit LAN SFP uplink
External power adapter
Power Provided
53.5 V - 1.31 A
78.13 Watt
FCC, RoHS
20.9 cm
12.6 cm
2.6 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 10
Managed: No
POE: PoE+
Brand: TP LINK
