TP LINK 10/100M RJ45 to 100M Single-Mode SC Fiber Converter
Quicklinx: 897NWS00 Mfr#: MC112CS
35 In Stock
£22.26 ex VAT
£26.71 inc VAT
The MC112CS is a media converter designed to convert 100BASE-FX fiber to 100Base-TX copper media or vice versa. Adopting WDM technology, MC112CS takes only one fiber cable to transmit and receive data, which will save half cabling cost for you. Designed under IEEE 802.3u 10/100Base-TX and 100Base-FX standards, the MC112CS is designed for use with single-mode fiber cable utilizing the SC-Type connector. The MC112CS supports longwave (LX) laser specification at a full wire speed forwarding rate. It works at 1310nm on transferring data and at 1550nm on receiving data. So the other end device to cooperate with the MC112CS should work at 1550nm on transferring data and at 1310nm on receiving data. Another TP-LINK's media converter MC111CS is just one of the examples to cooperate with MC112CS.
Other features of this module include the ability to be used as a stand alone device (no chassis required), Auto MDI/MDI-X for TX port, Auto negotiation of duplex mode on TX port, and front panel status LEDs. The MC112CS will transmit at extended fiber optic distances utilizing single-mode fiber up to 20 kilometers.
TP-Link MC112CS - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / SC single-mode
External
Cabling Type
10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 (TX) / 1550 (RX) nm
10Mb LAN, 100Mb LAN
Max Transfer Distance
20 km
9.5 cm x 7.3 cm x 2.7 cm
External
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
20 km
Status Indicators
Collision status, port duplex mode, power, link/activity
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
1 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x Ethernet 100Base-FX - SC single-mode
FCC
External power adapter
9.5 cm
7.3 cm
2.7 cm
10 - 90%
Type: Media Converter
Brand: TP LINK
