This battery is thin and lightweight while also improving safety. It is a portable charger that perfectly fits in your hand while working with your phone.
Power your digital life on the move
Housed in a portable design, TL-PB10000 is a high-capacity powerbank compatible your digital devices. With full capacity, it can hold enough juice to fully charge your device once or even more times. -
Flexible power
This high-capacity powerbank has 2 high-speed smart charging ports that detect the connected device and provide adaptive power output.
- TP-Link TL-PB10000 power bank - Li-pol - 2 x USB
- Product Type
- Power bank
- Output Connector Type
- 2 x USB
- Voltage Provided
- 5 V
- Max Electric Current
- 2.1 A
- Battery
- Lithium polymer - 10000 mAh
- Product Type
- Power bank
- Voltage Provided
- 5 V
- Output connectors
- 2 x 4 pin USB Type A
- 2.1 A
- Short circuit protection, overcharging protection, overheat protection, over voltage protection, over-current protection, overdischarging protection, Smart Charge Technology, pass-through charging
- Technology
- Lithium polymer
- Capacity
- 10000 mAh
