Toshiba Z20t Series Keyboard Dock
Quicklinx: BXF4WS00 Mfr#: PA5228E-1EKU
Get even more out of your Portégé Z10t-A with the dedicated Toshiba Z10t series keyboard dock. Simply slot your tablet into this stylish, connected dock to work more efficiently using the compact backlit keyboard - and transform your ultra-mobile device into a fully-featured workspace. It allows you to power through your workload while charging your tablet, whether you're browsing the Internet via Gigabit LAN or streaming videos using HDMI. You can also plug in your mouse, hard drive and external monitor through the USB 2.0 and VGA ports, for the added convenience of your essential office devices, without the desktop clutter.
Toshiba Keyboard Dock - keyboard - UK - graphite black metallic
Keyboard
Backlit
Localization and Layout
Pointing stick, ClickPad, integrated touchpad, status LED indicator, built-in rechargeable battery
Graphite black metallic
30.9 cm x 21.33 cm x 2.1 cm
780 g
1-year warranty
Dynabook Toshiba Portégé z20t, Z20t-B-102, Z20t-B-103, Z20t-B-104, Z20t-B-106, Z20T-B-107, Z20T-B-108, Z20t-B-10C, Z20t-B-10G, Z20t-B-10H, Z20T-B-11K, Z20t-B2110, Z20t-B2111, Z20t-B2112, Z20t-C-11H, Z20t-C-11Q, Z20t-C-121, Z20t-C-12F, Z20T-C-13R, Z20T-C-13T, Z20t-C-13X, Z20t-C-13Z, Z20t-C-155
Keyboard
Backlit
Input Device
30.9 cm
21.33 cm
2.1 cm
780 g
HDMI , VGA , 2 x USB 3.0 , LAN
Limited warranty - 1 year
