Toshiba Z20t Rugged Case
Quicklinx: BXFTWS00 Mfr#: PA1583U-1ZRC
The Portégé Z20t Rugged Case adds convenience and durability for the detachable Portégé Z20t display. A form fitted inner mold provides an additional layer of protection. The rubberized outer shell adds a shock-absorbing bumper. The built-in hand strap allows you to hold your tablet comfortably and securely, while allowing you to rotate the screen 360-degrees to the one perfect position.
Toshiba - notebook carrying case
Notebook carrying case
Product Material
Silicone, polycarbonate
32 cm x 2.1 cm x 21.1 cm
Notebook Compatibility
12.5"
Removable shoulder strap, rugged, adjustable handle, shock absorption, pen loop, ports and controls access
Dynabook Toshiba Portégé z20, Z20T
Product Material
32 cm
2.1 cm
21.1 cm
12.5"
Dynabook Toshiba Portégé z20t, Z20t-B-001, Z20t-B-005, Z20t-B-01Q, Z20t-B-102, Z20t-B-103, Z20t-B-104, Z20t-B-106, Z20T-B-107, Z20T-B-108, Z20t-B-10C, Z20t-B-10E, Z20t-B-10G, Z20t-B-10H, Z20t-B-10J, Z20t-B-10W, Z20t-B-10Z, Z20T-B-110, Z20t-B-111, Z20t-B-113, Z20t-B-115, Z20T-B-11E, Z20T-B-11K, Z20t-B-11P, Z20t-B-11Q, Z20t-B2110, Z20t-B2111, Z20t-B2112, Z20T-C-00Q, Z20t-C-11E, Z20t-C-11H, Z20t-C-11Q, Z20t-C-11R, Z20t-C-121, Z20t-C-127, Z20t-C-12F, Z20t-C-12R, Z20t-C-13Q, Z20T-C-13R, Z20T-C-13T, Z20t-C-13X, Z20t-C-13Z, Z20t-C-144, Z20t-C-155, Z20T-C-156
