**Toshiba Portege Z20t 2-in-1 with FREE Microsoft Arc Mouse & Miracast Adapter**
The power of an enterprise-class laptop. The freedom and convenience of a tablet. Why choose when you can get the best of both? The Toshiba Portégé Z20t Ultrabook offers innovative 2-in-1 versatility in a supremely crafted chassis, along with outstanding battery life and an exceptional handwriting experience.
**GREAT FOR PRESENTATIONS**
If you have to give presentations on a regular basis, you'll love the Portégé Z20t-B's ultimate business flexibility. With just one click, you can transform the Ultrabook™ into a high performance tablet to present your work to colleagues and clients. The device's integrated handwriting recognition means you can take notes easily because the words you write with the included pen are automatically converted to digital text. What's more, there's a HDMI port for quickly linking to large screens, and the Portégé Z20t-B's thin and lightweight form factor makes it easy to carry around between meetings.
**YOUR BUSINESS COMPANION**
When you're at your desk, in a meeting, giving a presentation, or simply on the go, the Portégé Z20t-B's extensive connectivity options enable you to hook up to all the peripherals you might need. You can connect to a second screen via the HDMI or RGB ports, and access the network through the Gigabit LAN port. Impressive laptop performance is always on hand to help you tackle your multiple daily tasks - and there's even a backlit keyboard for clearer typing in low light environments.
**PROVIDES PEACE OF MIND AT ALL TIMES**
However and wherever you work, it's important to know that your business's critical data is kept secure - at all times. That's why the Portégé Z20t-B offers a number of advanced features designed to provide you with peace of mind - leaving you to concentrate on getting your jobs done without distraction. The device's Trusted Platform Module (TPM) safeguards the data on local storage, while Intel® Active Management Technology (AMT) allows your IT department to monitor, maintain, repair, update and upgrade machines remotely.
**DESIGNED TO MAKE AN IMPRESSION**
First impressions count when you're meeting customers and clients. That's why the Portégé Z20t-B has been designed to look the part in any professional setting. Its innovative detachable functionality means you can show-off several modes of usage and its stylish magnesium alloy chassis always looks great. The Portégé Z20t-B's sturdy build won't let you down either: at just 21 mm thin in laptop mode and 8.8 mm in tablet mode, the device is deceptively durable. The chassis is drop-tested up to 76 cm / 30", making it ultra reliable for all your daily in- and out-of-office work.
**WORKS ALL DAY, EVERY DAY**
In today's world of always-on computing, your device needs to stand up to relentless everyday usage. The Portégé Z20t-B has been specifically tested for repeated usage and is equipped with a battery life of up to 17 hours* - that's two full working days of power, which means you won't have to charge up as frequently. Consequently, the Portégé Z20t-B is efficient to the core. It even has EPEAT Gold certification and the latest Energy Star qualification, so it can be classed as an environmentally preferable product. Plus, with Toshiba Eco Utility software, you can manage your PC settings to optimise your power consumption as you see fit. *Based on MobileMark 2012
**GOES WHERE YOU GO**
If work takes you out of the office, you'll be prepared for almost anything with the Portégé Z20t-B. Its matt, non-reflective screen means you can work comfortably in direct sunlight - and its slim design means you can carry it home easily when the sun goes down. You can even benefit from full PC performance when in tablet mode because the Ultrabook™ performance extends seamlessly across both of the device's modes. What's more, with the latest wireless options - including Bluetooth 4.0, Wi-Fi AC, Wi-Fi N and HSPA+/LTE - you'll still be able to connect to your colleagues wherever you go.
Twice as much to love
The Portégé Z20t Ultrabook just happens to be ultra-versatile, too. Unlike convertible PCs, it lets your workers detach the display for a true tablet experience, while giving them the traditional clamshell laptop they need to hammer out business emails, crunch numbers, craft proposals and stay productive on their feet - without buying two devices. -
Range expanded, potential unlimited
Camping beside power outlets can pose a serious disruption to mobile business, but with the Portégé Z20t Ultrabook those worries will be a thing of the past. -
The world's most write-minded PC
The Portégé Z20t Ultrabook comes with a 12.5" diagonal 10-point touch-enabled display producing crisp, clear Full HD images, while striking an ideal balance between size and portability. Plus, when paired with the advanced Wacom digitizer pen it also affords a superior handwriting experience enhanced by an antiglare coating. -
Do without the dongle
Connecting, syncing and sharing are essential parts of mobile business. That's why it was made sure that the Portégé Z20t Ultrabook has the ports people need - a LAN, RGB and full-size HDMI ports. And microSD, Micro HDMI plus a Micro USB 2.0 port on the tablet; and on the keyboard base two USB 2.0 ports, a USB 3.0 port. -
See the improvements, feel the difference
You spoke - and Toshiba listened. As a result, a good thing was made even better by equipping the Portégé Z20t Ultrabook with a larger touch pad. It also includes a full size keyboard providing a comfortable typing experience. -
A smart way to outsmart thieves
Convertible and detachable PCs can be vulnerable to theft but Toshiba has you covered. The Portégé Z20t Ultrabook was equipped with an innovative system allowing you to lock the tablet onto the keyboard dock with a special switch, making it immovable. Then, when you lock the keyboard base to a desk with a Kensington lock, you can walk away with confidence.
- Dynabook Toshiba Portégé Z20T-B-107 - 12.5" - Intel Core M - 5Y51 - 4 GB RAM - 128 GB SSD - with Microsoft Wireless Display Adapter and Arc Touch Bluetooth Mouse
- Product Type
- Ultrabook - flip design / detachable keyboard
- Operating System
- Win 8.1 Pro 64-bit
- Processor
- Intel Core M (5th Gen) - 5Y51 / 1.1 GHz, up to 2.6 GHz / 4 MB Cache
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 12.5" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 5300
- Input Device
- AccuPoint, digital pen, ClickPad
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 3-cell - up to 9 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip
- Dimensions (WxDxH) - tablet with keyboard
- 30.9 cm x 21.52 cm x 2.1 cm
- 1.51 kg
- Environmental Standards
- ENERGY STAR Qualified
- International warranty - 1 year - carry-in
- Bundled with
- Microsoft Wireless Display Adapter and Arc Touch Bluetooth Mouse
- Product Type
- Operating System
- Windows 8.1 Pro 64-bit Edition (preloaded)
- Bundled with
Processor / Chipset
- CPU
- Intel Core M (5th Gen) 5Y51 / 1.1 GHz
- Max Turbo Speed
- 2.6 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 128 GB SSD mSATA SATA
Display
- 12.5" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective, anti-fingerprint, Full HD wide-viewing angle (WVA)
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD (front), Full HD (rear)
- Resolution
- 5 Megapixel (rear)
- Camera Features
- Autofocus
- Sound
- Stereo speakers, stereo microphone
- DTS Studio Sound
Input
- Keyboard, AccuPoint, digital pen, ClickPad
- Spill-resistant, multi-touch clickpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 3-cell lithium polymer
- Installed Qty
- 2
- Run Time
- Up to 9 hours
- Run Time With Included Additional Battery
- Up to 17 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V, 2.37 A
Connections & Expansion
- Micro-USB 2.0 , 2 x USB 3.0 (on keyboard dock) , LAN (on keyboard dock) , VGA (on keyboard dock) , HDMI (on keyboard dock) , Micro-HDMI , Dock , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, EverNote, Toshiba Function Keys, Toshiba System Settings, Microsoft 365 (30 days trial), DTS Studio Sound, Toshiba Display Utility, McAfee LiveSafe (30 days subscription)
- Integrated Options
- Dockable
- Security
- Digital compass, Toshiba EasyGuard, Accelerometer, capacitive touch screen, gyroscope, hardened IOX Glass
- Included Accessories
- Stylus, power adapter
- 1.51 kg
- Dimensions (WxDxH) / Weight Details
- 30.9 cm x 19.99 cm x 0.88 cm / 730 g - tablet , 30.9 cm x 21.52 cm x 2.1 cm / 1.51 kg - tablet with keyboard
Sustainability Information
- ENERGY STAR Certified
