The Toshiba USB 3.0 to Gigabit Ethernet Adapter lets you add one RJ-45 Ethernet port to your USB-enabled laptop or desktop computer quickly and easily. Simply plug into a USB 3.0 port and enjoy data transfer rates of up to 1000 Mbps over your Gigabit network.
This compact adapter is USB 3.0 compliance and backward compatible with USB 2.0 or earlier version. It is an ideal network solution for both home and business environment and a great alternative for a gaming console that required network access but without Wi-Fi. It is USB bus-powered and does not require power adapter.
- Toshiba USB 3.0 Gigabit Ethernet Adapter - network adapter - USB 3.0 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- Gigabit Ethernet
- 2.1 cm x 7.44 cm x 1.6 cm
- 46.4 g
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- Data Transfer Rate
- 1 Gbps
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Windows 8
- 1-year warranty
- Designed For
- Dynabook Toshiba Portégé A30, Z20T, Z30, Z30t; Toshiba Satellite Pro A30, A40, A50, R40, R50; Toshiba Tecra A40, A50, Z40, Z40t, Z50; KIRA 10, 108; Satellite C40; Satellite Radius 11; 12; 14; 15
- Network adapter
- Form Factor
- External
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- 1 Gbps
- USB powered
- 1 x 1000Base-T - RJ-45
- Cables Included
- 1 x SuperSpeed USB cable (integrated)
- Software Included
- Driver
- OS Required
- 2.1 cm
- 7.44 cm
- 1.6 cm
- 46.4 g
- Limited warranty - 1 year
- Designed For
- Dynabook Toshiba Portégé A30-C-14R, A30-C-14U, A30-C-14X, A30-C-180, A30-C-1H2, A30-C-1HE, A30-C-1HF, Z20T-B-11K, Z20t-C-11E, Z20t-C-11H, Z20t-C-11Q, Z20t-C-121, Z20t-C-12F, Z20t-C-12R, Z20t-C-13Z, Z20t-C-155, Z30-B-12J, Z30-C-10N, Z30-C-10W, Z30-C-10Z, Z30-C-125, Z30-C-12U, Z30-C-138, Z30-C-13H, Z30-C-16J, Z30-C-16L, Z30-C-16N, Z30-C-16Z, Z30-C-193, Z30-C-1CV, Z30-C-1CW, Z30t-C-110, Z30t-C-139 , Dynabook Toshiba Satellite Pro A30-C-130, A30-C-14E, A30-C-182, A30-C-1EP, A30-C-1F3, A40-C-13U, A40-C-1D7, A50-C-12P, A50-C-12W, A50-C-1GL, A50-C-1GW, A50-C-1HF, A50-C-1HG, A50-C-1NC, A50-C-1ND, A50-C-1PR, A50-C-1TQ, A50-C-1U1, A50-C-207, A50-C-23P, A50-C-24W, R40-C-12H, R40-C-12W, R50-C-104, R50-C-14H, R50-C-14J, R50-C-15W, R50-C-179, R50-C-17C , Dynabook Toshiba Tecra A40-C-147, A40-C-15X, A40-C-17C, A40-C-1E5, A40-C-1HT, A40-C-1KE, A40-C-1KF, A50-C-1G0, A50-C-1H2, A50-C-1KC, A50-C-1QG, A50-C-1QK, A50-C-1RL, A50-C-1U2, A50-C-1UG, A50-C-1V0, A50-C-1W2, A50-C-200, A50-C-218, Z40-C-10R, Z40-C-11X, Z40-C-136, Z40-C-13N, Z40-C-146, Z40t-C-10L, Z40t-C-10M, Z50-C-114, Z50-C-115, Z50-C-11J, Z50-C-11W, Z50-C-140, Z50-C-151 , Toshiba KIRA 108, 10H, 10J, 10Q , Toshiba Satellite C40-C-10T , Toshiba Satellite Radius 11 CL10W-B-100 , Toshiba Satellite Radius 12 P20W-C-103, P20W-C-104, P20W-C-10H, P20W-C-10K , Toshiba Satellite Radius 14 L40W-C-109, L40W-C-10H, L40W-C-10L, L40W-C-10R, L40W-C-10V, L40W-C-10X, L40W-C-10Z, L40W-C-115 , Toshiba Satellite Radius 15 P50W-C-102, P50W-C-106, P50W-C-10E, P50W-C-10J, P50W-C-10P, P50W-C-10V
