Toshiba Tecra R950-1EN Core i5-3340M 4GB 320GB 15.6" Win 7 Pro 64bit/Win 8 Pro Upgarde
Quicklinx: 8NL9WS00 Mfr#: PT535E-05P01WEN
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Get down to business with the Tecra R950. It's the perfect 15.6" laptop for businesses demanding long-lasting performance. Built to last, it delivers up to long battery life for a full day out of the office and is extremely thin and light with excellent design using high-strength composite materials. The non-reflective screen and dedicated docking make it a comfortable and versatile companion. Featuring the powerful technologies for built-in manageability and security, it is ideal for fleet deployment.
  • Lasts longer
    The R950 is designed to go long distances. High-stiffness resin casing combined with an innovative inbuilt honeycomb structure, a spill-resistant keyboard and advanced Toshiba business features, help to protect the laptop and its data from shocks and drops. And you won't miss any office comforts thanks to the 15.6" non-reflective screen with LED backlighting and a spill-resistant keyboard with full-size format and separate numeric keypad.
  • Great connections
    This laptop features one USB 2.0 and two USB 3.0 ports for fast data transfer. USB sleep-and-charge lets you recharge your mobile devices without switching the computer on. If you need to transfer large files over your network quickly, then you'll love the built-in Gigabit LAN adapter. There's an internal slot for Bluetooth means you can sync your mobile devices without a cable and make video calls using a wireless headset. The DisplayPort connection gives you maximum flexibility when connecting to display devices. And for quick, easy connection to your entire office environment, there's the dedicated docking station port.
  • Reliable and secure for lower costs
    High stiffness resin casing combined with the innovative inbuilt honeycomb structure, durable hinges, a spill-resistant keyboard, and Toshiba's advanced HDD shock protection, help protect the laptop and its data from shocks and drops. The designs also endure a rigorous Highly Accelerated Life Test (HALT) to ensure your laptop can withstand extreme conditions. Fewer repairs, more secure data, longer life all mean better total cost of ownership.
  • Well-managed workforce
    The R950 makes it easy to manage a mobile workforce. For added security, there's a fingerprint reader and Trusted Platform Module for high-level data encryption. That's the IT department can keep you running safely and up-to-date even when away from the office.
  • Eco friendly
    The R950 features efficient, state-of-the-art power management and is ENERGY STAR qualified.
Dynabook Toshiba Tecra R950-1EN - 15.6" - Intel Core i5 3340M - vPro - 4 GB RAM - 320 GB HDD - 3G
Notebook
Operating System
Win 7 Pro 64-bit
Platform Technology
Intel vPro Platform
Intel Core i5 (3rd Gen) 3340M / 2.7 GHz (3.4 GHz) / 3 MB Cache
4 GB DDR3 (1 x 4 GB)
Storage
320 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4000
Input Device
DualPoint
Numeric Keypad
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
Wireless Broadband (WWAN)
3G
6-cell - up to 10 hours
Dockable
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
Graphite black with grooved texture, matte black keyboard
37.9 cm x 25.2 cm x 2.54 cm
2.49 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
International warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Chipset
Mobile Intel QM77 Express
Platform Technology
Intel vPro Platform
Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
8 GB
DDR3 SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
320 GB HDD SATA 3Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Max Allocated RAM Size
1696 MB
Camera
Resolution
1 Megapixel
Video Resolutions
1280 x 800
Sound
Stereo speakers, microphone
Codec
Realtek ALC269Q
High Definition Audio, SRS Premium Sound HD
Input
Keyboard, DualPoint
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Centrino Advanced-N 6235
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel 82579LM
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
Generation
3G
GSM, GPRS, EDGE, HSDPA, HSUPA, HSPA+
Controller
Ericsson F5321gw
Max Transfer Rate
21 Mbps
Navigation
Receiver
A-GPS
6-cell Lithium Ion
66 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
65 Watt, 19 V, 3.42 A
Connections & Expansion
VGA , LAN , Headphone/microphone combo jack , USB 2.0/eSATA , DisplayPort , USB 2.0 , 2 x USB 3.0 , Dock
Memory Card Reader
Yes (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, xD-Picture Card, SDHC Card)
Software
Software Included
Toshiba TEMPRO Performance Tuning Service, McAfee Internet Security Suite (30 days subscription), Skype, Infineon TPM Professional Package, Toshiba Assist, Toshiba PC Health Monitor, Toshiba Recovery Media Creator, Toshiba Eco Utility, Toshiba Security Assist, Toshiba HDD Protection, Toshiba Service Station, Microsoft Office 2010 Starter, Toshiba HDD/SSD Alert, Nero Kwik Media, Nero BackItUp & Burn Autobackup, Toshiba Intelligent Display Management, Windows 8 Pro 64-bit (DVD)
Case Material
Polycarbonate ABS
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Toshiba EasyGuard, Intel Active Management Technology (iAMT), USB Sleep-and-charge ports
Power adapter
Localization
2.49 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
