Engineered with Experience
Built on 30 years of experience in manufacturing premium laptops, Toshiba’s Tecra A50-C and your business are the perfect match. The A50-C is designed for long-lasting versatility, while also remaining professional with a slim appearance and subtle, yet distinct design – striking a balance between aesthetic appeal, exterior durability and interior performance.
The Tecra Standard
Fulfil your users’ business requirements with high performance and reliability. The power of an Intel® Core™ CPU up to i7 helps users stay productive from the start of the day right through to its end. And inside, premium components meet the high standard of quality for which the Tecra series is renowned. Intel® HD or Nvidia GT930M graphics ensure a clear view from the 39.6 cm (15.6") HD or Full HD screen, while the optional 256 GB SSD means that your business’ most important documents, data, and media are to hand, in and out of the office.
Connected to your Business
Toshiba's Tecra A50-C enables you to output your onscreen content to two Ultra HD displays using the optional High Speed Replicator III docker. The docker conveniently allows you and your staff to extend the laptop's viewing capacity across external displays with ease - ideal for working on multiple documents at once, or sharing presentations with colleagues.
Reliability from Toshiba
Spill- and drop-resistant, the Tecra A50-C is designed to withstand the challenges of mobile usage, as tested and proven by the device’s H.A.L.T. compliance. Inside, the 3D HDD Impact Sensor protects the HDD in the event of physical damage, keeping your business-critical data intact, while outside, a silent heavy-typer keyboard withstands even the most demanding workloads.
Easy to use, Easy to manage
Manage a single Tecra A50-C, or an entire fleet with ease, thanks to a number of features that enable remote control and network-based management. The integrated high-speed Gigabit LAN facilitates rapid delivery of patches from an SCCM infrastructure, while the WMI-enabled bios allows the same SCCM system to remotely manage and configure all settings. What’s more, the A50-C is protected by McAfee LiveSafe software from the moment the device is turned on.
Environmentally Responsible
Take control of your business’ energy consumption by better managing your power settings with Toshiba’s Eco Utility software, built into the Tecra A50-C. The device is also EPEAT certified, confirming it as eco-friendly, and has qualified for the latest Energy Star rating for its state-of-the-art energy efficiency.
Your Business Toolkit
While the Tecra A50-C is a great standalone business laptop, its benefits can be extended even further with a range of licensed Toshiba accessories. Increase the number of ports and make your A50-C into a connection hub with the Toshiba Dynadock or HSPR III docking station, and support heavier workloads with B2B-specific external storage devices, whether they be HDD, SSD, SD Cards or USB sticks. And for protection throughout the day, Toshiba also offers a range of bags and sleeves – allowing you to tailor the Tecra experience to your users’ exact requirements.
Your laptop, your way
Go to Toshiba Direct and can configure your Tecra A50 laptop anyway way you like, with the specific business-class features you need to perform at your peak. -
Business-class features - for first-class results
Don't use everyday technology to get your important work done. Boot up the Tecra A50 laptop, common docking, a dedicated numeric 10-key pad for smoother data entry, HDMI, VGA, eSATA plus USB 3.0 ports, along with Intel AGN or BGN wireless options. -
Get and give a stellar performance
With the Tecra A50 laptop, we've cut out all the enterprise-class features you don't need, but kept all the performance you do. Fire up 4th Gen Intel Core processors for multitasking, crunching numbers or staying productive with the latest apps. -
Built to last
Shock-absorbing design, unique honeycomb-reinforced chassis and other extras, The Tecra A50 laptop proudly carries the Tecra tradition of durability. It embodies Toshiba's reputation for quality and reliability, thanks to highly accelerated life testing in our factory. -
Range far and wide
A longer battery life rating frees you to travel farther and stay productive longer between charges. The Tecra A50 laptop has a removable standard six-cell battery that can easily be swapped out for a high-capacity battery.
- Dynabook Toshiba Tecra A50-C-17C - 15.6" - Core i5 5200U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
- Processor
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz (2.7 GHz) / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 8 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- Tile black (keyboard), steel grey with precious hairline
- 37.9 cm x 25.8 cm x 2.325 cm
- 2.4 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, stereo microphone
- DTS Studio Sound
Input
- Keyboard, touchpad
- Numeric Keypad
- Palm Rejection Technology, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi), Wake-on-LAN (WOL)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Capacity
- 45 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- 2 x USB 2.0 , 2 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
- Case Material
- Aluminum, polycarbonate ABS
- Dockable
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, remote boot control
- Included Accessories
- Power adapter
- Localization
- 2.4 kg
- ENERGY STAR Certified
