TOSHIBA TDP-S8 PROJECTOR LAMP
Quicklinx: 51Z2WS00 Mfr#: TLPLV6
You never know when your lamp might fail, so it's smart to carry a back-up on business trips or keep a spare at your presentation facility. The replacement lamp from Toshiba is a lifesaver if your bulb burns out. The durable lamp will give you hundreds of hours of excellent, crisp, clear brightness.
Toshiba TDP-LV6 - projector lamp
Projector lamp
90 days warranty
TDP-S8, S8U, T8, T9, T95, T9U
Projector lamp
Limited warranty - 90 days
Toshiba TDP-S8, S8U, T8, T9, T95, T9U
