Upscaling and value. The SD3005-2 is an upscaling DVD player that allows you to enjoy standard definition DVDs in near high definition. HDMI allows easy connection to your HD TV as well as upscaling to 720p, 1080i and 1080p resolution. MP3 and JPEG files are supported as well as a wide range of DVD and CD disc formats. The SD3005 includes REGZA-link technology so you can control the player with the same remote control as your TV.
HDMI
HDMI connectivity provides an easy way to connect your DVD recorder to you HD TV and upscales your standard definition DVDs to 720p, 1080i or 1080p for an enhanced viewing experience. -
MP3
Use your DVD player for more than watching DVDs, listen to your MP3 music files via CD-R and CD-RW. -
JPEG
Enjoy photos on the big screen by viewing them on your TV via your DVD player. -
REGZA Link
HDMI-CEC technology allows you to control the DVD Player with the same remote control as your TV.
- Toshiba SD3005-2 - DVD player
- Product Type
- DVD player
- 33 cm x 20.9 cm x 4.3 cm
- 1.25 kg
- Media Type
- CD-R, CD-RW, DVD-R, DVD+RW, DVD-RW, DVD+R, CD-ROM, DVD-ROM, Video CD, DVD-R DL
- Media Format
- NTSC
- Upscaling
- Yes (up to 1080p)
- Sound Output Mode
- Stereo
- Power
- AC 120/230 V (50/60 Hz)
- Form Factor
- Tabletop
- Enclosure Colour
- Black
- Product Type
- DVD player
- Form Factor
- Tabletop
- 33 cm
- 20.9 cm
- 4.3 cm
- 1.25 kg
- Enclosure Colour
- Black
DVD
- Media Type
- Media Format
- NTSC
- Media Load Type
- Tray
- Upscaling
- Yes (up to 1080p)
- Audio Formats
- MP3
- Photo Formats
- JPEG
Blu-ray & DVD Features
- Picture Zoom
- On-screen display, slow motion mode, REGZA LINK
Audio System
- Sound Output Mode
- Stereo
- Surround Sound Effects
- 3D Virtual Surround Sound
- Digital Audio Format
- Dolby Digital output, DTS digital output
- Connector Type
- Composite video output (RCA) - rear , Digital audio output (coaxial) (RCA) - rear , SCART (21 PIN SCART) - rear , HDMI output (19 pin HDMI Type A) - rear , Audio line-out (RCA x 2) - rear
- Power Device
- Power supply - internal
- Voltage Required
- 10 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- Width (Shipping)
- 39.5 cm
- Depth (Shipping)
- 8.6 cm
- Height (Shipping)
- 29.6 cm
- Weight (Shipping)
- 1.88 kg
Toshiba SD3010KB Upscaling DVD Player
