Toshiba SBM1W Mini 3D Sound Bar with Subwoofer
Quicklinx: 91YYWS00 Mfr#: PA5075E-1SPA
Toshiba's Plug-and-Play Mini 3D Sound Bar with subwoofer offers consumers a simple way to introduce robust audio to their entertainment experience in the home by delivering a total peak power of 90 watts.
Measuring in at a mere 11.4 inches long by 3.9 inches wide and only 2.8 inches high, its uniquely compact design allows it to be placed within confined spaces, including home offices, dorm rooms and kitchen countertops, to add a boost in sound without adding much to the space taken up by a TV.
The Mini 3D Sound Bar offers users up to five different ways to connect to a device, including two analog connections, two digital connections and Bluetooth wireless technology that makes it possible for users to link the sound bar to mobile consumer electronics including tablets, PCs and smartphones to wirelessly play back audio.
  • Make the sweet spot wherever you sit
    Make your whole room a sweet spot with the Mini 3D Sound Bar. The coolest addition to your HDTV or other devices, it takes up little space, but provides awesome, immersive audio to complete that full entertainment experience you want.
  • Truly seamless 3D sound
    Many popular systems promise an "immersive" listening experience. Yet they all fall apart at the seams, with "dead spots" depending on where you sit. The Mini 3D Sound Bar uses advanced Sonic Emotion technology to provide an all-new, all-enveloping audio experience. It's based on sound field control incorporating spatial analysis and wave field synthesis. But you won't think about the science - just the incredible sound coming from that one small Plug-and-Play device.
  • Compact simplicity and convenience
    5.1 and other so called immersive audio systems are nice to listen to. But they can also be very complicated to set up, position and calibrate. Plus, they often take up a lot of space, and add cable clutter. Not the Mini 3D Sound Bar. It's small, simple to set up and delivers incredible 3D sound without an array of external speakers.
  • Broad device compatibility
    You might buy the Mini 3D Sound Bar to match great sound to the great picture on your HDTV. But don't forget all your other digital gear. Onboard Bluetooth lets you easily link with your smartphone or tablet. Plus, an array of digital and analog inputs allow you to enjoy full, rich, extra-realistic sound from a computer, MP3 or Blu-ray Disc player, and of course your television.
Toshiba Mini 3D Sound Bar - sound bar system - wireless
Sound bar system
System Components
Subwoofer, sound bar
Speaker Type
Active
Peak Power
80 Watt
Frequency Response
95 - 19000 Hz
Bluetooth
Speaker System Details
1 x sound bar 60 Watt 4 Ohm , 1 x subwoofer 20 Watt 8 Ohm
Sound Effects
Sonic Emotion Absolute 3D Sound
1-year warranty
Dynabook Toshiba Portégé Z10t-A-102, Z10t-A-122; Toshiba Satellite Pro C50, C50-A-15, C50-A-169, C70-A-11, C70-A-14, C870, L50-A-12, L70-A-140, L850, L870-17, NB10t-A-109; Toshiba Tecra R950, R950-19; Qosmio X870-162; Satellite C55t-A-104, P50t-A-123, P70-A-12, P845t-10, P875-31, U840T-101
Sound bar system
Enclosure Colour
Speaker System
System Components
Speaker Type
Active
Peak Power
80 Watt
Frequency Response
95 - 19000 Hz
Signal-To-Noise Ratio
65 dB
Sound Effects
Bluetooth
Speakers Included
1 x sound bar - 60 Watt - 4 Ohm - wireless , 1 x subwoofer - 20 Watt - 8 Ohm - wired
Driver Details
Sound bar: 4 x full-range driver - 2.01"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 4.02"
Connector Type
SPDIF input (RCA) , SPDIF input (TOS Link) , Audio line-in (RCA x 2) , Audio line-in (mini-phone stereo 3.5 mm)
AC power adaptor, audio cable, remote control
Remote Control
Remote control
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Sound bar: 29 cm x 7.2 cm x 10 cm / 0.85 kg , Subwoofer: 22 cm x 22 cm x 24.6 cm / 2.83 kg
Limited warranty - 1 year
Dynabook Toshiba Portégé Z10t-A-102, Z10t-A-122 , Dynabook Toshiba Satellite Pro C50-A-15T, C50-A-169, C50-A-1FM, C70-A-11N, C70-A-11Q, C70-A-14X, C870-1CR, L50-A-12L, L70-A-140, L850-1PG, L870-17R, NB10t-A-109 , Dynabook Toshiba Tecra R950-19D, R950-1C1, R950-1C6, R950-1G5 , Toshiba Qosmio X870-162 , Toshiba Satellite C55t-A-104, P50t-A-123, P70-A-12K, P845t-10R, P875-31Z, U840T-101
