Toshiba Satellite Pro R50-C-15W 15.6 INCH - Ci3-6006U 4GB 500GB DVDR
Quicklinx: DFCZWS00 Mfr#: PS571E-07906LEN
Display Size: 15.6in
Processor Model: I3-6006U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 500GB
  • Core i3
  • IEEE 802.11n
£457.77 ex VAT
£549.32 inc VAT
PROFESSIONAL PERFORMANCE
The Satellite Pro R50-C has been designed specifically to meet the requirements of professionals. The device offers a solid combination of performance and reliability – backed up by Toshiba’s history of over 30 years of notebook development. Designed to be a reliable companion in the business environment, the Satellite Pro R50-C has a keyboard that can withstand heavy daily use, a 3D sensor for data protection, and is drop tested to ensure its ruggedness.
LONG TERM VALUE
The Satellite Pro R50-C is a cost effective device that professionals can rely on. That’s because the device has been built to last – making it great value for money in the long run. You can feel reassured by a solid design that’s built to withstand the pressures of daily use – with a selection of the latest features that won’t date quickly.
THE STANDALONE SOLUTION
Built to work straight out of the box, the Satellite Pro R50-C reaches maximum performance without relying on external peripherals. With Intel® Core™ architecture, Wi-Fi and LAN capabilities, the device single-handedly delivers on every professional demand. The Satellite Pro R50-C has a 38.1cm (15") matt screen that combats the glare of office lighting, an advanced system that supports silent working and a full size keyboard for added convenience and comfort.
PREMIUM WITHOUT THE PRICETAG
With premium components housed in a highly resistant body, the Satellite Pro R50-C is built to handle the challenges of even the most demanding professional environments. The device is secure, too: A Kensington lock slot offers security for the device itself. And McAfee security software is pre-installed to protect all your data from the moment the laptop is turned on.
CONNECTED TO YOUR BUSINESS NEEDS
The Satellite Pro R50-C is well connected, enabling you to save, store and share data however suits you best. With HDMI, RGB, USB 3.0 and LAN, connecting to peripherals in or out of the office is easy. Plus, there’s an SD card slot enabling you to rapidly export data away from the machine when required.
PERSONALISE YOUR PROFESSION
The Satellite Pro R50-C supports a wide range of accessories designed for business users. You can quickly connect additional displays and desktop peripherals with the Dynadock range, extend hard drive space with Toshiba’s external devices, and transport and store the device safely with official bags, sleeves, trolleys and more.
CERTIFIED ECO-FRIENDLY
Take control of your environmental impact with Toshiba’s EPEAT Gold certified Satellite Pro R50-C with Eco Utility built-in. You can quickly and easily customise your computer settings to maximise power efficiency, minimise energy consumption, and reduce the impact your work has on the planet.
Services for a flawless performance
The impeccable operation of your Toshiba product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
  • Long term value
    The Satellite Pro R50-C is a cost effective device that professionals can rely on. That's because the device has been built to last - making it great value for money in the long run. You can feel reassured by a solid design that's built to withstand the pressures of daily use.
  • The standalone solution
    Built to work straight out of the box, the Satellite Pro R50-C reaches maximum performance without relying on external peripherals. With advanced architecture, Wi-Fi and LAN capabilities, the device single-handedly delivers on every professional demand. The Satellite Pro R50-C has a matt screen that combats the glare of office lighting, an advanced system that supports silent working and a full size keyboard for added convenience and comfort.
Dynabook Toshiba Satellite Pro R50-C-15W - 15.6" - Core i3 6006U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i3 (6th Gen) 6006U / 2 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell - up to 8 hours
3-axis accelerometer
Security
Trusted Platform Module (TPM 2.0) Security Chip
Graphite black, black (keyboard)
37.9 cm x 25.8 cm x 2.395 cm
2.1 kg
Region: United Kingdom
Pricing Type
BTO
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Hyper-Threading Technology, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - HD
Resolution
0.9 Megapixel
Sound
Stereo speakers, microphone
DTS Sound
Input
Keyboard, touchpad
Numeric Keypad
Multi-gesture touch pad, spill-resistant, Palm Rejection Technology
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 8 hours
AC Adapter
Input
AC 120/230 V
Output
19 V, 2.37 A
Connections & Expansion
2 x USB 2.0 , 2 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft Office 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription)
Integrated Options
Security
Administrator password, system password, hard drive password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
Pricing Type
BTO
2.1 kg
ENERGY STAR Certified
Software applications
Toshiba Satellite Pro R50-C-15W 15.6 INCH - Ci3-6006U 4GB 500GB DVDR Bundle deal on Toshiba Satellite Pro R50-C-15W 15.6 INCH - Ci3-6006U 4GB 500GB DVDR
£639.94
saving £8.33
£556.94
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Graphics: Intel HD Graphics 520
Hard Drive Type: HDD
Type: Laptop
Brand: Toshiba
Price Range Ex VAT: 300 - 500
