Toshiba Satellite Pro L830-17T Intel Core i3-3227U 2GB 500GB 13.3" Windows 8 64bit
Quicklinx: 8XS6WS00 Mfr#: PSKF3E-00T00DEN
  • Core i3
  • Windows 8 64-bit Edition
  • IEEE 802.11n
  • Bluetooth 4.0
The 33.8 cm (13.3") Satellite Pro L830 series is for businesses who want a laptop offering great mobility, reliability and value. This 'mobile' features a classy design and comes loaded with the Core i3 processor and connectivity. Despite the compact dimension, Toshiba has managed to fit a HD webcam and SRS Premium HD sound into the L830 for full multimedia performance.
  • Compact power
    The Satellite Pro L830 is ideal for businesses seeking a mobile all-rounder. The Core i3 processor and long battery life make it a flexible solution for business of all sizes.
  • Hands-on computing
    Special care has been taken to make sure that the L830 is a joy to use. The tile keyboard has perfect finger response and is easy to clean. The hard disk is protected by a 3D sensor from the inevitable bump on the road. So you'll always feel good, even when you are working hard.
  • Great connections
    The L830 features one USB 2.0 and two USB 3.0 ports for fast data transfer. USB Sleep-and-Charge lets you recharge your mobile devices without switching the computer on. Bluetooth 4.0 means that you can sync your mobile devices without a cable and make video calls using a wireless headset. The HDMI connection gives you full flexibility when connecting to display devices.
  • Multimedia on board
    Unlike many small business laptops, the L830 has a full set of multimedia features. There's SRS Premium HD sound to support your business presentations. The 1.0 megapixel webcam delivers high-definition resolution for your video conferences. And an HDMI port is available to plug into a large screen.
Dynabook Toshiba Satellite Pro L830-17T - 13.3" - Intel Core i3 3227U - 2 GB RAM - 500 GB HDD
Notebook
Operating System
Win 8 64-bit
Intel Core i3 (3rd Gen) 3227U / 1.9 GHz / 3 MB Cache
2 GB DDR3 (1 x 2 GB)
Storage
500 GB HDD / 5400 rpm
Display
13.3" LED backlight TruBrite 1366 x 768 / HD
Graphics
Intel HD Graphics 4000
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
Up to 4.5 hours
Matt & glossy crossline pattern, black keyboard
32.9 cm x 22.1 cm x 3.062 cm
1.86 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Enhanced SpeedStep technology
RAM
2 GB (1 x 2 GB)
Max RAM Supported
16 GB
DDR3 SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 5400 rpm
Display
13.3"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, TruBrite
Audio & Video
Graphics Processor
Max Allocated RAM Size
782 MB
Camera
Resolution
1 Megapixel
Video Resolutions
1280 x 800
Sound
Stereo speakers, microphone
Codec
CX20671
High Definition Audio, SRS Premium Sound HD
Input
Keyboard, touchpad
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Atheros WB222
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
Lithium Ion
48 Wh
Run Time
Up to 4.5 hours
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
2 x USB 3.0 , LAN , VGA , Headphone output , HDMI , USB 2.0 , Microphone input
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Toshiba TEMPRO Performance Tuning Service, McAfee Internet Security Suite (30 days subscription), Microsoft Office (Trial), Toshiba PC Health Monitor, Toshiba Recovery Media Creator, Toshiba Eco Utility, Toshiba HDD Protection, Toshiba Service Station, Toshiba Media Player, Toshiba Video Player, Toshiba Places, Toshiba Resolution+, SRS Premium Sound HD, Intel AppUp Center, McAfee Security Advisor, Microsoft Fresh Paint, Microsoft Solitair Collection, Toshiba Function Keys, Toshiba Desktop Assist, Toshiba System Settings, Intel Rapid Storage Technology
Case Material
Polycarbonate ABS
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, USB Sleep-and-charge ports, Intel Rapid Storage Technology (iRST)
Power adapter
Localization
1.86 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
