The Satellite Pro C660D combines three of the important things you need from a laptop - performance, reliability, and value. Designed to offer users peace of mind, the C660D combines efficient processing with advanced ergonomics and secure connectivity, providing leading performance. A textured design provides style and comfort, and various configurations make it easy to find the model that suits your needs. Delivering outstanding value, the Satellite Pro C660D offers business performance you can trust - at a budget-friendly price.
Classic business design
Designed to meet Toshiba's premium standards, the Satellite Pro C660D features a streamlined and textured design, adding a touch of style to everyday business computing. The compact, hard-wearing chassis also offers signature Toshiba build quality that provides protection for internal components, making the C660D perfect for use in a busy office environment. -
Comfortable computing
Combining an ergonomic design with a range of business features, the Satellite Pro C660D offers both comfort and performance. The 15.6" Toshiba TruBrite HD screen displays documents in sharp detail, and a non-reflective HD screen allows you to work in bright conditions, reducing reflections to avoid mirroring that can be caused by sunlight. A stylish keyboard also provides comfort when typing, and a 10-digit numeric keypad makes financial data input quick and easy. -
Easy operation
For business professionals, ease of use is essential, and the Satellite Pro C660D is designed to make life simple. A multi-touch touch pad allows you to pinch, rotate, and swipe your way through applications with added accuracy, and the integrated webcam features Toshiba face recognition so you can log-on to your PC without having to type in a password. -
Business connectivity
Complete flexibility is provided by a range of interfaces, including USB 2.0 and Wireless LAN b/g/n. offering all the tools you need to stay connected, the Satellite Pro C660D also features Toshiba ConfigFree, which makes it easier to manage wireless connections. An integrated microphone, combined with the integrated speakers, make it possible to host video conferences with colleagues.
- Dynabook Toshiba Satellite Pro C660D-187 - 15.6" - E-350 - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Home Premium 64-bit
- Processor
- AMD E-350 1.6 GHz / 1 MB Cache
- Memory
- 4 GB DDR3 (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight TruBrite 1366 x 768 / HD
- Graphics
- AMD Radeon HD 6310
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 3.0 HS, 10/100 Ethernet
- Battery
- Up to 5.3 hours
- Black with textured pattern
- 38.1 cm x 25.4 cm x 3.6 cm
- 2.3 kg
- Microsoft Office Preloaded
- Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Home Premium 64-bit Edition
Processor / Chipset
- CPU
- AMD E-350 1.6 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 1 MB
- 64-bit Computing
- Chipset
- AMD A50M
- PowerNow! technology
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3 SDRAM
- Speed
- 1066 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, TruBrite
Audio & Video
- Graphics Processor
- Max Allocated RAM Size
- 1981 MB
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC259
- High Definition Audio
- Audio Features
- Output: Toshiba Bass Enhanced Sound System
Input
- Keyboard, touchpad
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Atheros AR9285
- Network Interface
- 10/100 Ethernet
- Wi-Fi CERTIFIED
- Technology
- Lithium Ion
- Capacity
- 4400 mAh
- Run Time
- Up to 5.3 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- VGA , 2 x USB 2.0 , Headphone output , Microphone input , LAN
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Drivers & Utilities, Toshiba ConfigFree, Connectivity Doctor, McAfee Internet Security Suite (30 days subscription), Toshiba Supervisor Password Utility, Toshiba Bluetooth Stack, Skype, Toshiba Assist, Windows Live Essentials, ebay, Toshiba Recovery Media Creator, Toshiba Photo Service, Toshiba Disc Creator, WildTangent Game Console, Toshiba Value Added Package, Chicony Camera Assistant Software, Face Recognition software, Bing Toolbar, Amazon, Nero BackItUp & Burn Essentials, Microsoft Office 2010 Starter, Toshiba Music Place, Nero Multimedia Suite 10 Essentials
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN
- Localization
- 2.3 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80%
