Toshiba Satellite Pro C660D-185 AMD E350 4GB 320GB 15.6 Windows 7 Professional 64 bit laptop
Quicklinx: 7HMMWS00 Mfr#: PSC1ZE-003002EN
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
The Satellite Pro C660D combines three of the important things you need from a laptop - performance, reliability, and value. Designed to offer users peace of mind, the C660D combines efficient processing with advanced ergonomics and secure connectivity, providing leading performance. A textured design provides style and comfort, and various configurations make it easy to find the model that suits your needs. Delivering outstanding value, the Satellite Pro C660D offers business performance you can trust - at a budget-friendly price.
  • Classic business design
    Designed to meet Toshiba's premium standards, the Satellite Pro C660D features a streamlined and textured design, adding a touch of style to everyday business computing. The compact, hard-wearing chassis also offers signature Toshiba build quality that provides protection for internal components, making the C660D perfect for use in a busy office environment.
  • Comfortable computing
    Combining an ergonomic design with a range of business features, the Satellite Pro C660D offers both comfort and performance. The 15.6" Toshiba TruBrite HD screen displays documents in sharp detail, and a non-reflective HD screen allows you to work in bright conditions, reducing reflections to avoid mirroring that can be caused by sunlight. A stylish keyboard also provides comfort when typing, and a 10-digit numeric keypad makes financial data input quick and easy.
  • Easy operation
    For business professionals, ease of use is essential, and the Satellite Pro C660D is designed to make life simple. A multi-touch touch pad allows you to pinch, rotate, and swipe your way through applications with added accuracy, and the integrated webcam features Toshiba face recognition so you can log-on to your PC without having to type in a password.
  • Business connectivity
    Complete flexibility is provided by a range of interfaces, including USB 2.0 and Wireless LAN b/g/n. offering all the tools you need to stay connected, the Satellite Pro C660D also features Toshiba ConfigFree, which makes it easier to manage wireless connections. An integrated microphone, combined with the integrated speakers, make it possible to host video conferences with colleagues.
Dynabook Toshiba Satellite Pro C660D-185 - 15.6" - E-350 - 4 GB RAM - 320 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit
AMD E-350 1.6 GHz / 1 MB Cache
4 GB DDR3 (1 x 4 GB)
Storage
320 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight TruBrite 1366 x 768 / HD
Graphics
AMD Radeon HD 6310
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 3.0 HS, 10/100 Ethernet
Up to 5.3 hours
Black with textured pattern
38.1 cm x 25.4 cm x 3.6 cm
2.3 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
AMD E-350 1.6 GHz
Number of Cores
Dual-Core
Cache
L2 - 1 MB
64-bit Computing
Chipset
AMD A50M
PowerNow! technology
RAM
4 GB (1 x 4 GB)
Max RAM Supported
8 GB
DDR3 SDRAM
Speed
1066 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
320 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, TruBrite
Audio & Video
Graphics Processor
AMD Radeon HD 6310
Max Allocated RAM Size
1981 MB
Camera
Resolution
0.3 Megapixel
Sound
Stereo speakers, microphone
Codec
Realtek ALC259
High Definition Audio
Audio Features
Output: Toshiba Bass Enhanced Sound System
Input
Keyboard, touchpad
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Atheros AR9285
Network Interface
10/100 Ethernet
Wi-Fi CERTIFIED
Lithium Ion
4400 mAh
Run Time
Up to 5.3 hours
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
VGA , 2 x USB 2.0 , Headphone output , Microphone input , LAN
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Drivers & Utilities, Toshiba ConfigFree, Connectivity Doctor, McAfee Internet Security Suite (30 days subscription), Toshiba Supervisor Password Utility, Toshiba Bluetooth Stack, Skype, Toshiba Assist, Windows Live Essentials, ebay, Toshiba Recovery Media Creator, Toshiba Photo Service, Toshiba Disc Creator, WildTangent Game Console, Toshiba Value Added Package, Chicony Camera Assistant Software, Face Recognition software, Bing Toolbar, Amazon, Nero BackItUp & Burn Essentials, Microsoft Office 2010 Starter, Toshiba Music Place, Nero Multimedia Suite 10 Essentials
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN
Localization
2.3 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
