Toshiba Satellite Pro C660-16W Core 2 Duo T6670 2.2 GHz 3Gb 250GB 15.6" Windows 7 Home Premium 64bit
Toshiiba Satellite Pro C660
Quicklinx: 77JDWS00 Mfr#: PSC0ME-00N00SEN
  • Core 2 Duo
  • Microsoft Windows 7 Home Premium 64-bit Edition
  • IEEE 802.11n
The Satellite Pro C660 combines three of the important things you need from a laptop - performance, reliability, and value. Designed to offer users peace of mind, the C660 combines efficient processing with advanced ergonomics and secure connectivity, providing leading performance. A textured design provides style and comfort, and various configurations make it easy to find the model that suits your needs. Delivering outstanding value, the Satellite Pro C660 offers business performance you can trust - at a budget-friendly price.
  • Classic business design
    Designed to meet Toshiba's premium standards, the Satellite Pro C660 features a streamlined and textured design, adding a touch of style to everyday business computing. The compact, hard-wearing chassis also offers signature Toshiba build quality that provides protection for internal components, making the C660 perfect for use in a busy office environment.
  • Comfortable computing
    Combining an ergonomic design with a range of business features, the Satellite Pro C660 offers both comfort and performance. The 15.6" Toshiba TruBrite HD screen displays documents in sharp detail, and a non-reflective HD screen allows you to work in bright conditions, reducing reflections to avoid mirroring that can be caused by sunlight. A stylish keyboard also provides comfort when typing, and a 10-digit numeric keypad makes financial data input quick and easy.
  • Easy operation
    For business professionals, ease of use is essential, and the Satellite Pro C660 is designed to make life simple. A multi-touch touch pad allows you to pinch, rotate, and swipe your way through applications with added accuracy, and the integrated webcam features Toshiba face recognition so you can log-on to your PC without having to type in a password.
  • Business connectivity
    Complete flexibility is provided by a range of interfaces, including USB 2.0 and Wireless LAN b/g/n. offering all the tools you need to stay connected, the Satellite Pro C660 also features Toshiba ConfigFree, which makes it easier to manage wireless connections. An integrated microphone, combined with the integrated speakers, make it possible to host video conferences with colleagues.
Dynabook Toshiba Satellite Pro C660-16W - 15.6" - Core 2 Duo T6670 - 3 GB RAM - 250 GB HDD
Notebook
Operating System
Win 7 Home Premium 64-bit
Intel Core 2 Duo T6670 / 2.2 GHz / 2 MB Cache
3 GB DDR3 (1 x 1 GB + 1 x 2 GB)
Storage
250 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight TruBrite 1366 x 768 / HD
Graphics
Intel GMA 4500MHD
Numeric Keypad
Integrated Webcam
802.11b/g/n, 10/100 Ethernet
Up to 4.5 hours
Black with textured pattern
38.1 cm x 25.4 cm x 3.6 cm
2.3 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - pick-up and return
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L2 - 2 MB
64-bit Computing
Front Side Bus
800 MHz
Chipset
Mobile Intel GM45 Express
Enhanced SpeedStep technology
RAM
3 GB (1 x 1 GB + 1 x 2 GB)
Max RAM Supported
8 GB
DDR3 SDRAM
Speed
1066 MHz
Slots Qty
2
Empty Slots
0
Storage
Main Storage
250 GB HDD SATA 1.5Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, TruBrite
Audio & Video
Graphics Processor
Intel GMA 4500MHD
Memory Allocation Technology
Dynamic Video Memory Technology 5.0
Max Allocated RAM Size
1340 MB
Camera
Resolution
0.3 Megapixel
Sound
Stereo speakers, microphone
Codec
Realtek ALC259
High Definition Audio
Audio Features
Output: Toshiba Bass Enhanced Sound System
Input
Keyboard, touchpad
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
802.11b/g/n
Network Interface
10/100 Ethernet
Lithium Ion
4400 mAh
Run Time
Up to 4.5 hours
AC Adapter
Input
Connections & Expansion
VGA , 2 x USB 2.0 , Headphone output , Microphone input , LAN
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Drivers & Utilities, Toshiba ConfigFree, Connectivity Doctor, McAfee Internet Security Suite (30 days subscription), Toshiba Supervisor Password Utility, Nero 9 Essentials, Skype, Toshiba Assist, Windows Live Essentials, ebay, Toshiba Recovery Media Creator, Toshiba Photo Service, Toshiba Disc Creator, WildTangent Game Console, Toshiba Value Added Package, Chicony Camera Assistant Software, Face Recognition software, Bing Toolbar, Amazon, Nero BackItUp & Burn
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password
Localization
2.3 kg
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
