Toshiba Satellite Pro C50-A-136 Intel Core i3-3120M 4GB 500GB 15.6" Windows 7 Pro (+ Windows 8 Pro)
Quicklinx: 8XSDWS00 Mfr#: PSCG7E-00500DEN
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Satellite Pro C50-A comes with quality, reliability and value built in. Simply open it up and you're ready for business. The Intel Core i5 processor delivers an impressive performance from the start. Plus there's a full set of ports for faster, easier connections to your network and other devices. With all-round functionality from a brand you can rely on, this affordable Satellite Pro is always ready to do business.
  • Built for your business
    Whatever the size and nature of your business, there's a Satellite Pro C50-A for you. With the Core processor, you can create the ideal business laptop for your everyday needs. And because C50-A configuration delivers a reliable performance at an affordable price, you get plenty of added value every time you use it.
  • Smarter investment
    With a proven reputation for business laptops, the Satellite Pro range is the professional's choice. And you can see why, when dedicated business features, higher speeds and an efficient performance come as standard. Add to that Toshiba quality you can count on, and the reasonably-priced C50-A becomes a really smart investment.
  • Maximum flexibility
    The C50-A is versatile, in and out the office. You have a choice of USB 2.0 and USB 3.0 ports to transfer data to your storage devices. And you can zip it there up to 10 times faster using USB 3.0. With HDMI, you have the flexibility to share your work on display devices. And you get the wireless freedom to sync your mobile devices too, with Bluetooth 4.0 built in.
  • Consistently reliable
    You rely on your business laptop. So you need to know that it will perform, day after day. With the Intel Core i5 processor and a fast 7200 rpm HDD, the C50-A delivers a consistently powerful performance, from boot-up to shut-down.
  • Commercial comfort
    If you're looking to combine comfort with productivity, then the C50-A has all the answers. You can expect amazing picture quality with no harsh glare from the non-reflective 39.6 cm (15.6") HD LED backlight display. And an improved full-size keyboard with a useful numeric keypad, for faster number-crunching.
Dynabook Toshiba Satellite Pro C50-A-136 - 15.6" - Intel Core i3 3120M - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit
Intel Core i3 (3rd Gen) 3120M / 2.5 GHz / 3 MB Cache
4 GB DDR3 (1 x 4 GB)
Storage
500 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4000
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
Up to 3.5 hours
Matt black with hairline pattern, black keyboard
38 cm x 24.2 cm x 3.335 cm
2.3 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Enhanced SpeedStep technology, Hyper-Threading Technology
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3 SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Max Allocated RAM Size
1771 MB
Camera
Resolution
0.9 Megapixel
Video Resolutions
1280 x 720
Sound
Stereo speakers, microphone
Codec
Realtek ALC269Q
High Definition Audio, DTS Sound
Input
Keyboard, touchpad
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
Lithium Ion
48 Wh
Run Time
Up to 3.5 hours
AC Adapter
Input
Output
65 Watt, 19 V, 3.42 A
Connections & Expansion
2 x USB 3.0 , LAN , VGA , Headphone output , HDMI , USB 2.0 , Microphone input
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Windows 8 Pro 64-bit (DVD), Microsoft 365 (30 days trial), DTS Sound
Case Material
Polycarbonate ABS
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN
Power adapter
Localization
2.3 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 90%
