Toshiba Satellite Pro A30-C-10G i5-6200U 4GB 500GB 13.3" Win 7 Pro
Quicklinx: BW01WS00 Mfr#: PT361E-001001EN
  • Core i5
  • Microsoft Windows 7 Professional
  • IEEE 802.11n
  • Bluetooth 4.0
Stay connected, stay productive - be mobile. Work and learn wherever you are, with the 13.3" Satellite Pro A30-C - the mobile laptop that never compromises on performance, connectivity, or durability. Long battery life makes the A30-C ready to replace the paper notebook as your go-to learning tool.
  • Learn wherever you are
    The Satellite Pro A30-C's compact form fits into any bag comfortably, so it's ideal to carry from place to place. But that's not all that makes it perfect for learning and working on the move - with its high-quality HD display, you can work anywhere, even in bright sunlight. And with a battery life that will keep going for a long time, you're never interrupted by the need to find a socket and plug in.
  • The PC you can count on
    Designed to withstand the everyday bumps and strains of agile learning, the Satellite Pro A30-C's lightweight but robust magnesium chassis will never let you down.
  • Connect to knowledge
    The Satellite Pro A30-C comes with a range of dongle-free connectivity possibilities - including HDMI, three USB 3.0 ports for saving and sharing content at speed, and premium Wi-Fi performance - so you can connect and collect learning materials hassle-free. The A30-C also features an excellent Full HD webcam.
  • Perform to achieve
    Although the Satellite Pro A30-C is super-mobile, it never compromises on performance. That's because it's built with advanced internal components like the powerful processor. With the A30-C, you can get things done as fast as you need to - making it perfect for working between meetings, or getting your essay done as your deadline approaches.
  • Professional levels of security
    Whether it's your dissertation or your business's critical data, there are some things you don't want getting into the wrong hands. With the Satellite Pro A30-C, you can rest assured thanks to its TPM (Trusted Platform Module). That way, you're protected from the first time you press the power button.
Dynabook Toshiba Satellite Pro A30-C-10G - 13.3" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
13.3" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 9.5 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip
Black (keyboard), black magnesium with precious hairline
31.6 cm x 22.9 cm x 2.24 cm
1.5 kg
Region: United Kingdom
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence (preloaded)
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
13.3"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, stereo microphone
DTS Studio Sound
Input
Keyboard, touchpad
Built-in numeric keyboard, multi-gesture touch pad, Palm Rejection Technology
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 9.5 hours
AC Adapter
Input
Output
19 V, 2.37 A
Connections & Expansion
Interfaces Details
3 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
Security
Security lock slot (cable lock sold separately), administrator password, system password
Power adapter
Localization
1.5 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
BW01 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
