You never know when your service replacement lamp might fail, so it's smart to carry a back-up on business trips or keep a spare one at your presentation facility. This service replacement lamp from Toshiba is a lifesaver if your bulb burns out. This durable service replacement lamp will give you hundreds of hours of excellent, crisp, clear brightness.
- Toshiba TLP-LW11 - projector lamp
- Product Type
- Projector lamp
- Designed For
- TLP-WX2200, WX2200U, WX2200UK, X2000, X2000EDU, X2000U, X2500, X2500A, XC2000, XC2000U, XC2500, XC2500A, XC2500AU, XC2500U, XD2000, XD2000U
- Product Type
- Projector lamp
- Designed For
- Toshiba TLP-WX2200, WX2200U, WX2200UK, X2000, X2000EDU, X2000U, X2500, X2500A, XC2000, XC2000U, XC2500, XC2500A, XC2500AU, XC2500U, XD2000, XD2000U
