Toshiba Portege Z30A1GX Intel Core i5-4210U 8GB 256GB 13.3" Windows 7 Professional
Quicklinx: B3DVWS00 Mfr#: PT243E-0JL053EN
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
With an ultra-thin, premium design the high-performance Toshiba Portégé Z30-A Ultrabook was made to keep business moving. A long-lasting battery and Intel Core i5 processor for Ultrabook will help you power through the working day while the ultra-light form and full-size ports give you all the flexibility you need on the go. The Z30-A's durable magnesium chassis has been rigorously drop- and spill-tested and also comes with high-level security and manageability technologies.
  • Ultra-light for business anywhere
    The Portégé Z30-A was made to move. Starting at an ultra-light and highly robust, it's the perfect companion to take on your business travels. And if you're out and about in direct sunlight, you won't see any glare on the non-reflective HD screen with LED backlighting. So it's really convenient to type emails or create documents, in or out the office – even in dimly lit conditions, using the illuminated keyboard.
  • Power and performance, without compromise
    With Intel Core i5 processor, your laptop has all the power you need to multitask on the move or in the office. And with a high-performance SSD inside, the Portégé Z30-A delivers faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. There's no compromise, so you can run all of your business applications with ease.
  • Better connected on the move
    The Portégé Z30-A is packed with mobile flexibility – and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster, using three of the USB 3.0 ports or share your presentations in high-resolution brilliance, with HDMI. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly. So you can be more productive anywhere.
  • Secure and easy to manage
    The Z30-A is built for business, so comes loaded with tried-and-tested security and management features. There's the self-encrypted drives and Trusted Platform Module (TPM) to safeguard the critical data on your local storage. And even if your Z30-A needs to be updated, the IT department can do it at any time, with Intel Active Management Technology (AMT). The standard fingerprint reader makes it easy and secure to log on to your PC too.
  • Business improvements all round
    Toshiba has added metal hinges, silent cooling and better speakers to the design to make the Z30 more durable and user-friendly. With a HD screen and improved backlit keyboard, plus larger Accupoint and touchpad, it's easier to view and navigate your Z30-A too.
Dynabook Toshiba Portégé Z30-A-1GX - 13.3" - Intel Core i5 - 4210U - 8 GB RAM - 256 GB SSD
Ultrabook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD
Display
13.3" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 4400
Input Device
DualPoint
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 10 hours
Dockable
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
Steel gray metallic, matte black keyboard
31.6 cm x 22.7 cm x 1.79 cm
1.2 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Ultrabook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Processor / Chipset
CPU
Intel Core i5 (4th Gen) 4210U / 1.7 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD mSATA SATA 3Gb/s
Display
13.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, microphone
High Definition Audio, DTS Studio Sound
Input
Keyboard, DualPoint
Keyboard Backlight
Spill-resistant, multi-touch clickpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 3160
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-V
Intel Wireless Display (WiDi), Wake-on-LAN (WOL)
Wi-Fi CERTIFIED
4-cell lithium polymer
52 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
LAN , VGA , HDMI , 3 x USB 3.0 , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, Windows 8.1 Pro 64-bit (DVD)
Case Material
Magnesium alloy
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Toshiba EasyGuard, USB Sleep-and-charge ports
Power adapter
Localization
1.2 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
Shock Tolerance (operating)
10 g
Shock Tolerance (non-operating)
60 g
Vibration Tolerance (operating)
0.5 g
Vibration Tolerance (non-operating)
1 g
