The Portégé Z30-C was made to move. Light and highly robust, it's the perfect companion to take on your business travels. You get many hours of battery life on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the great screen with LED backlighting.
Light for business anywhere
The Portégé Z30-C was made to move. Light and highly robust, it's the perfect companion to take on your business travels. You get many hours on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the great screen with LED backlighting. -
Great power and performance
With the advanced processor your laptop has all the power you need to multitask on the move or in the office. The Portégé Z30-C delivers faster speeds and higher responsiveness from the second you boot up to the minute you shut down. There's no compromise, so you can run all of your business applications with ease. -
Better connected on the move
The Portégé Z30-C is packed with mobile flexibility - and because all ports are full size, you won't need any special adapter. You can transfer data to other devices much faster. Or share your presentations in high-resolution brilliance with HDMI. Gigabit LAN also allows fast access to your local network, so you can be more productive anywhere. -
You can depend on it
The ultra-durable Portégé Z30-C was designed to withstand the pressures of professional life. With its light yet strong magnesium chassis, the Portégé Z30-C is robust enough to withstand ultra-mobile business, so you can be sure of a higher return on your investment.
- Dynabook Toshiba Portégé Z30-C-16H - 13.3" - Core i5 6200U - 4 GB RAM - 128 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 128 GB SSD
- Optical Drive
- No optical drive
- Display
- 13.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Input Device
- DualPoint, ClickPad
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 14 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Steel gray metallic, matte black keyboard
- 31.6 cm x 22.7 cm x 1.79 cm
- 1.2 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, two microphones
- DTS Studio Sound
Input
- Keyboard, DualPoint, ClickPad
- Multi-touch clickpad, gesture function
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 14 hours
AC Adapter
- Input
- AC 120/230 V
- Output
- 19 V, 2.37 A
Connections & Expansion
- 2 x USB 3.0 , HDMI , VGA , Headphone/microphone combo jack , LAN , Dock , USB 3.0 (Sleep & Charge)
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft Office 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription)
- Case Material
- Magnesium alloy
- Dockable
- Security
- Administrator password, system password, hard drive password
- Theft/Intrusion Protection
- Included Accessories
- Power adapter
- TUV Rheinland
- Localization
- 1.2 kg
- ENERGY STAR Certified
