With an ultra-thin, premium design that travels light and is professional through and through, the high-performance 33.8 cm (13.3") Toshiba Portégé Z30-A was made to keep business moving. A long-lasting battery, full-size ports and Intel Core processor for Ultrabook help you power through the working day. And because the Portégé Z30-A comes with high-level security and manageability technologies in an ultra-durable chassis, your data will be protected too. High performance goes ultra-mobile, with the Portégé Z30-A.
Ultra-light for business anywhere
The Portégé Z30-A was made to move. Starting at an ultra-light and highly robust, it's the perfect companion to take on your business travels. Even without an extended battery, you get a long-lasting time on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the 33.8 cm (13.3") non-reflective HD screen with LED backlighting. So it's really convenient to type emails or create documents, in or out the office - even in dimly lit conditions, using the illuminated keyboard. -
Power and performance, without compromise
With Intel Core processor, your laptop has all the power you need to multitask on the move or in the office. And with a high-performance SSD inside, the Portégé Z30-A delivers faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. There's no compromise, so you can run all of your business applications with ease. -
Better connected on the move
The Portégé Z30-A is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster, using three of the latest USB 3.0 ports. Or share your presentations in high-resolution brilliance, with HDMI. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly. So you can be more productive anywhere. -
Secure and easy to manage
The Z30-A is built for business, so comes loaded with tried-and-tested security and management features. There's the self-encrypted drives and Trusted Platform Module (TPM) to safeguard the critical data on your local storage. And even if your Z30-A needs to be updated, the IT department can do it at any time, with Intel Active Management Technology (AMT). The standard fingerprint reader makes it easy and secure to log on to your PC too. -
Synergy across devices
The Portégé Z30-A shares many features with the business line-up from Toshiba, to ensure consistency across your company. So you can easily access all of your peripherals using a wide range of ports, with the common docking station. The Z30-A also comes with dongle-free connectivity in the form of HDMI, RGB, Gigabit LAN and three USB 3.0 ports for added convenience and flexibility.
- Dynabook Toshiba Portégé Z30-A-1D6 - 13.3" - Intel Core i7 - 4600U - vPro - 8 GB RAM - 256 GB SSD - 4G LTE
- Product Type
- Ultrabook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (4th Gen) - 4600U / 2.1 GHz, up to 3.3 GHz / 4 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 13.3" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4400
- Input Device
- DualPoint
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- 4-cell - up to 12 hours
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
- Steel gray metallic, matte black keyboard
- 31.6 cm x 22.7 cm x 1.79 cm
- 1.2 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Product Type
- Ultrabook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i7 (4th Gen) 4600U / 2.1 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD mSATA SATA 3Gb/s
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 2 Megapixel
- Video Resolutions
- 1980 x 1080
- Sound
- Stereo speakers, stereo microphone
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, DualPoint
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7260
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Generation
- 4G
- Technology
- GSM, GPRS, EDGE, HSPA+, LTE
- Controller
- Sierra Wireless AirPrime EM7305
Navigation
- Receiver
- A-GPS
- Technology
- 4-cell lithium polymer
- Capacity
- 52 Wh
- Run Time
- Up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- VGA , LAN , HDMI , Headphone/microphone combo jack , 3 x USB 3.0 , Dock
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, Windows 8.1 Pro 64-bit (DVD)
- Case Material
- Magnesium alloy
- Dockable
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Toshiba EasyGuard, Intel Active Management Technology (iAMT), USB Sleep-and-charge ports
- Included Accessories
- Power adapter
- Localization
- 1.2 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
