Don't let the sleek and light design of Portégé laptops leave you thinking they're light on power, too. But when time comes to get the job done, they really get down to business. With the powerful processor beneath the hood you'll be multitasking effortlessly. And thanks to long battery life ratings, you can go through your day worry-free.
Portégé laptops help you stay shielded and constantly mobile thanks to this suite of safeguards against shocks, spills and falls. You'll also enjoy enhanced security for your data with features like a fingerprint reader, or more peace of mind with a spill-resistant keyboard.
No compromise performance
Don't let the sleek and light design of Portégé laptops leave you thinking they're light on power, too. But when time comes to get the job done, they really get down to business. With the powerful processor beneath the hood you'll be multitasking effortlessly. And thanks to long battery life ratings, you can go through your day worry-free. -
Easyguard technology
Portégé laptops help you stay shielded and constantly mobile thanks to this suite of safeguards against shocks, spills and falls. You'll also enjoy enhanced security for your data with features like a fingerprint reader, or more peace of mind with a spill-resistant keyboard. -
Strong, reliable and durable
True to Toshiba's heritage of innovation, Portégé PCs have been engineered with unique design features for a stronger, more reliable, thinner and lighter laptop. Check out magnesium alloy casings with honeycomb structures for a stronger and enhanced durability and rigidity, shock-absorbing designs, and the impact-smart hard drive for added protection. -
So green they won gold
The Portégé family of PCs not only helps you excel and look good, but feel good as well, knowing you've got an advanced green technology. -
Packed with many amenities
Portégé laptops are rich in features that make mobile life easier - and you more effective. A built-in optical drive on select models, solid state drives, LED backlit displays and long battery life ratings are just a few examples.
- Dynabook Toshiba Portégé Z30T-B-10E - 13.3" - Intel Core i5 - 5200U - 4 GB RAM - 128 GB SSD
- Product Type
- Ultrabook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Processor
- Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 128 GB SSD
- Display
- 13.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 5500
- Input Device
- DualPoint
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 14.5 hours
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
- Steel gray metallic, matte black keyboard
- 31.6 cm x 22.7 cm x 1.79 cm
- 1.36 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- International warranty - 1 year - carry-in
- Product Type
- Ultrabook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD mSATA SATA
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, stereo microphone
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, DualPoint
- Spill-resistant, multi-touch clickpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-V
- Intel Wireless Display (WiDi), Wake-on-LAN (WOL)
- Wi-Fi CERTIFIED
- Technology
- 4-cell lithium polymer
- Capacity
- 52 Wh
- Run Time
- Up to 14.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- VGA , HDMI , Headphone/microphone combo jack , 3 x USB 3.0 , LAN , Dock
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, Windows 8.1 Pro 64-bit (DVD)
- Case Material
- Magnesium alloy
- Dockable
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, remote boot control, Toshiba EasyGuard, USB Sleep-and-charge ports
- Included Accessories
- Power adapter
- Localization
- 1.36 kg
Sustainability Information
- ENERGY STAR Certified
