Ultra-mobile performance, robust Portege design. Ultra-mobile and fully featured, the Portege R700 is a premium business machine for those who refuse to compromise. Full performance processor and the Airflow Cooling technology provide more power and reduced heat for best-in-class computing, and a robust magnesium design protects against system damage and PC down-time. Battery provides enough power to complete a full working day, meaning you can be fully operational wherever you are. Why choose between performance and portability when you can have both?
High power cooling for full power performance
An advanced cooling system contributes to the Portege R700's outstanding and highly mobile business design. Thanks to the Airflow Cooling technology, the R700 features a full-performance processor, offering power and mobility side-by-side. Heat-generating components are efficiently grouped together next to a compact integrated fan system, reducing heat so the latest processing technology can provide advanced business performance - all in a slim, compact body you can take anywhere. -
Complete durability
A durable design offers the advanced protection required for mobile business use. In addition to the magnesium chassis, a ultra-durable honeycomb structure integrated beneath the palm-rests provides extra protection of key internal components. Shielding against any structural damage caused by carrying the laptop while in use, the reinforced chassis also features a spill-resistant keyboard - helping to protect your data, increasing reliability and reducing PC down time. -
Long lasting and ultra-mobile
A thin, light and robust design makes the Portege R700 perfect for the traveling user. At just 26mm with an integrated DVD drive and long-lasting battery, you can enjoy advanced, powerful business performance with no bulk. And you'll always have enough power for a full day's work. Whether you're traveling, in a meeting or just moving around the office, the Portege R700 provides the perfect platform to get the job done. -
Stunning detail, advanced control
A 33.8cm (13.3") HD LED backlight screen provides unparallel clarity, regardless of what's on display. Whether working on documents, presentations or spreadsheets, every detail is displayed with pin-sharp clarity. An ergonomic, tiled keyboard designed for professionals provides a stylish, comfortable facility for regular typing. A multi-touch touchpad also allows you to pinch, swipe and zoom through a wide range of controls and shortcuts, making it quicker and easier to operate business applications. -
Build for business
In addition to the USB input, you'll have a USB/eSATA combo port make it easy to connect to phones and external storage, and VGA and HDMI ports mean you can connect to HD screens. For time-pressured business users who require flexibility, instant docking provides a quick way to connect to a range of peripheral hardware in one go. -
Toshiba EasyGuard
Fully equipped with Toshiba EasyGuard features - more security, protection, connectivity, and manageability - the Portege R700 delivers the technology in a stunning, ultra-mobile and robust package. -
Eco power
Thanks to Toshiba's unique, energy-saving Eco utility software, you can now go green at the touch of a button. Eco utility reduces power consumption as you work and lets you monitor energy savings, allowing you to actively reduce the amount of energy your PC consumes on a daily, weekly or monthly basis. The PC Health Monitor also highlights irregular power consumption and keeps a record of battery health.
- Dynabook Toshiba Portégé R700-1DH - 13.3" - Core i3 350M - 2 GB RAM - 320 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro
- Processor
- Intel Core i3 350M / 2.26 GHz / 3 MB Cache
- Memory
- 2 GB DDR3 (1 x 2 GB)
- Storage
- 320 GB HDD / 7200 rpm
- Display
- 13.3" LED backlight anti-reflective 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 2.1 EDR, Gigabit Ethernet
- Battery
- Up to 8.9 hours
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader
- Black magnesium, brushed metallic finish
- 31.6 cm x 22.7 cm x 2.6 cm
- 1.28 kg
- Microsoft Office Preloaded
- Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- International warranty - 3 years - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM55 Express
- Enhanced SpeedStep technology, Execute Disable Bit capability
- RAM
- 2 GB (1 x 2 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3 SDRAM
- Speed
- 1066 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 320 GB HDD SATA 1.5Gb/s / 7200 rpm
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Dynamic Video Memory Technology 5.0
- Max Allocated RAM Size
- 728 GB
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC269Q
- High Definition Audio
- Audio Features
- Output: Toshiba Bass Enhanced Sound System
Input
- Keyboard, touchpad
- Spill-proof, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Centrino Advanced-N 6200
- Network Interface
- Gigabit Ethernet
- Wi-Fi CERTIFIED
- Technology
- Lithium Ion
- Capacity
- 6200 mAh
- Run Time
- Up to 8.9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
Connections & Expansion
- VGA , LAN , Microphone input , Headphone output , 2 x USB 2.0 , USB 2.0/eSATA , HDMI
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card)
Software
- Software Included
- Drivers & Utilities, Toshiba ConfigFree, Connectivity Doctor, McAfee Internet Security Suite (30 days subscription), Toshiba Supervisor Password Utility, Nero 9 Essentials, Toshiba Bluetooth Stack, Skype, Toshiba Assist, Windows Live Essentials, ebay, Toshiba Recovery Media Creator, Toshiba Photo Service, Toshiba Bluetooth Monitor, Toshiba Disc Creator, WildTangent Game Console, Toshiba Value Added Package, Chicony Camera Assistant Software, Face Recognition software, Bing Toolbar, Amazon, Nero BackItUp & Burn Essentials
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Intel Anti-Theft Technology (iAT), Toshiba EasyGuard
- Localization
- 1.28 kg
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80%
