The Toshiba Primary Battery Pack is a rechargeable, Lithium Ion battery. Used as either a spare or replacement battery, this battery pack meets or exceeds the specifications of the original battery that came with your notebook. It interfaces with the Toshiba Power Saver Utility on the notebook which features a charge indicator to help you monitor the available power.
- Toshiba Primary Battery Pack - laptop battery - Li-Ion - 6200 mAh
- Laptop battery
- 317.5 g
- Battery
- Lithium Ion 6-cell - 6200 mAh
- 20.8 cm x 4.3 cm x 2 cm
- 1-year warranty
- Designed For
- Dynabook Toshiba Portégé R700, R700 3G/EX-1DZ, R700 EX-11, R700 EX-123, R705, R830, R930; Toshiba Tecra R700, R840, R940; Satellite R630, R830, R930
- Laptop battery
- Technology
- 6-cell Lithium Ion
- Voltage Provided
- 10.8 V
- Capacity
- 6200 mAh
- RoHS
- Limited warranty - 1 year
- 20.8 cm
- 4.3 cm
- 2 cm
- 317.5 g
- Designed For
- Dynabook Toshiba Portégé R700 3G/EX-1DZ, R700 EX-11G, R700 EX-123, R700-01B, R700-02B, R700-100, R700-110, R700-12D, R700-12K, R700-12R, R700-135, R700-136, R700-14F, R700-14L, R700-14M, R700-14N, R700-153, R700-157, R700-158, R700-15C, R700-15E, R700-15H, R700-15J, R700-15L, R700-15V, R700-15Z, R700-16R, R700-173, R700-174, R700-177, R700-179, R700-17G, R700-17H, R700-17N, R700-17W, R700-17X, R700-17Z, R700-181, R700-182, R700-183, R700-184, R700-185, R700-187, R700-18C, R700-18G, R700-18P, R700-18Q, R700-19F, R700-19L, R700-19M, R700-19T, R700-1C2, R700-1C4, R700-1CC, R700-1CF, R700-1CQ, R700-1CX, R700-1CZ, R700-1D1, R700-1D3, R700-1DC, R700-1DD, R700-1DE, R700-1DF, R700-1DG, R700-1DH, R700-1DJ, R700-1DL, R700-1DM, R700-1DN, R700-1DP, R700-1DT, R700-1E0, R700-1E1, R700-1EG, R700-1EH, R700-1EL, R700-1EZ, R700-1F0, R700-1F1, R700-1F2, R700-1F3, R700-1F4, R700-1F5, R700-1F6, R700-1F7, R700-1FK, R700-1FL, R700-1FN, R700-1FP, R700-1G0, R700-1G4, R700-K01, R700-K02, R700-K03, R700-K05, R700-S1312, R700-S1322, R700-S1322W, R700-S1332, R700-S1332W, R700-ST1303, R700-W1322, R830-0F5, R830-0F6, R830-0H4, R830-0KF, R830-1G2, R930-109, R930-10J, R930-115, R930-116, R930-117, R930-12Q, R930-13U, R930-14T, R930-14X, R930-14Z, R930-151, R930-152, R930-153, R930-18L, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, R930-1FU, R930-1FV , Dynabook Toshiba Tecra R840-17Q, R840-17R, R840-198, R940-1CV, R940-1CW, R940-1D6, R940-1DC, R940-1EE, R940-1FD, R940-1FE, R940-1FF, R940-1FH, R940-1FT, R940-1GQ, R940-1GT, R940-1JF, R940-1JG, R940-1JH, R940-1KF, R940-1KR, R940-1L0, R940-1L1, R940-1MJ , Toshiba Satellite R630-102, R630-105, R630-130, R630-131, R630-139, R630-13K, R630-13N, R630-13P, R630-13R, R630-13T, R630-13U, R630-13V, R630-13Z, R630-140, R630-141, R630-144, R630-145, R630-146, R630-148, R630-149, R630-14H, R630-14J, R630-14R, R630-14T, R630-14X, R630-153, R630-155, R630-156, R830-1G0, R830-1GZ, R830-1L7, R930-16W, R930-1CV
