The Toshiba primary battery pack is a 6-cell, rechargeable, Lithium-ion battery designed to work with various Toshiba series portable computers. Take your office on the road without sacrificing performance, productivity or convenience with Toshiba notebook battery packs. Battery power gives you the ability to use your computer around the house, on campus, in the office, and when you travel either on business trips or vacation. Enhanced battery life helps you stay connected and be productive wherever your work takes you. Used as either a spare or replacement battery, this battery pack meets or exceeds the specifications of the original battery that came with your notebook.
- Toshiba - laptop battery - Li-Ion - 4400 mAh
- Laptop battery
- Battery
- Lithium Ion 6-cell - 4400 mAh
- Designed For
- Satellite C650, C650D, C655, C655D, C660, C660D, C670, C670D, L730, L735, L750, L750D, L755, L755D, L770, L770D, L775, L775D, P750, P770
- Laptop battery
- Technology
- 6-cell Lithium Ion
- Voltage Provided
- 10.8 V
- Capacity
- 4400 mAh
- Designed For
- Toshiba Satellite C650-01E, C650-028, C650-02S, C650-054, C650-06E, C650-BT5N11, C650D-006, C650D-02U, C650D-BT2N11, C650D-BT5N11, C650D-ST2NX1, C650D-ST3NX1, C650D-ST4NXQ, C650D-ST5N01, C650D-ST5NX1, C650-ST2NX1, C650-ST2NX2, C650-ST3NX1, C650-ST4NX1, C650-ST5N02, C650-ST5N03, C650-ST5NX1, C650-ST5NX2, C650-ST6N02, C655D-S5133, C655D-S5234, C655D-S5536, C655-S5092, C655-S5235, C655-S5305, C655-S5512, C655-S5514, C655-S5542, C655-SP5292M, C660-00J, C660-01C, C660-02L, C660-03C, C660-1CL, C660-1M4, C660-1ML, C660-1PD, C660-1X3, C660-224, C660-25C, C660-27Z, C660-28W, C660-2CF, C660-2EV, C660-2G9, C660-2KE, C660-2KW, C660-2L0, C660-2L9, C660-2LM, C660-2ML, C660-2MM, C660-2N3, C660-2N5, C660-2N9, C660-2PE, C660-2PP, C660-2Q7, C660-2QB, C660-2QH, C660-2QN, C660-2QV, C660-2QZ, C660-2R1, C660-2RC, C660-2RG, C660-2RP, C660-2RZ, C660-2T6, C660-2T7, C660-2TC, C660-2TU, C660-2U7, C660-2UD, C660-2VM, C660D-17J, C660D-1D7, C660D-1EH, C660D-1FV, C660D-1FW, C660D-1G5, C660D-1G6, C660D-1GJ, C660D-1GQ, C660D-1GW, C660D-1GZ, C660D-1H2, C660D-1HD, C660D-1HK, C670-03G, C670-104, C670-12N, C670-13K, C670-13P, C670-17C, C670-17G, C670-17M, C670-17Q, C670-17V, C670-186, C670-189, C670-19E, C670-19F, C670-1C4, C670-1C8, C670-1CK, C670-1CP, C670-1CV, C670-1D3, C670-1D4, C670-1D5, C670-1D9, C670-1DC, C670-1DF, C670-1DJ, C670-1DL, C670-1DP, C670-1DV, C670-1DW, C670D-11Z, C670D-12L, C670D-12Q, C670D-12T, C670D-12V, C670D-12Z, C670D-134, C670D-135, L730-121, L735-14L, L735-157, L735-158, L750-12M, L750-12T, L750-17N, L750-1RJ, L750-22C, L750-22J, L750-22X, L750-22Z, L750D-07N, L750D-199, L750D-1C7, L750D-1CC, L750D-1ER, L750D-1EX, L750D-1GC, L755-1HW, L755-1HX, L755-1HZ, L755-1J5, L755-1J8, L755-1LL, L755-1LM, L755-1LQ, L755-1MU, L755-1NM, L755-1NP, L755D-13D, L755D-14H, L755D-14N, L755D-14X, L755D-21L, L770-068, L770-0DW, L770D-050, L775-139, L775-17T, L775D-10F, L775D-10Q, L775D-10R, P750-11S, P750-141, P750-15F, P750-15G, P750-15L, P770-13H
