You never know when your service replacement lamp might fail, so it's smart to carry a back-up on business trips or keep a spare one at your presentation facility. This service replacement lamp from Toshiba is a lifesaver if your bulb burns out. This durable service replacement lamp will give you hundreds of hours of excellent, crisp, clear brightness.
- Toshiba TLP-LW2 - projector lamp
- Product Type
- Projector lamp
- Designed For
- TLP-T520, T520E, T521, T521E, T620, T621, T720, T720U, T721, T721U
- Product Type
- Projector lamp
- Designed For
- Toshiba TLP-T520, T520E, T521, T521E, T620, T621, T720, T720U, T721, T721U
