Toshiba L200 1TB 2.5" 5400rpm 8MB SATA Internal HDD
Quicklinx: BPR1WS00 Mfr#: HDWJ110UZSVA
Toshiba’s L200 2.5" internal hard drive is designed for everyday laptop users and gamers – and it's ideal for boosting and upgrading the storage capacity of your laptop PC or games console by up to 1 TB. Perpendicular Magnetic Recording and Tunnel Magneto-Resistive technologies also ensure fast, stable recording that makes the most of your hard drive space. Available in capacities of up to 1 TB, the L200 puts the renowned durability and reliability of Toshiba technology to work in your notebook or game console.
  • Enhanced durability
    Equipped with Advanced Format technology and a shock sensor, the Toshiba L200 Laptop PC hard drive is designed to withstand the rigors of daily use, ensuring your data is protected against everyday bumps and shakes.
  • Optimized performance
    With a data transfer rate of 600 MBps and Native Command Queuing (NCQ), this internal hard drive optimizes read and write operations for improved efficiency, making it ideal for multitasking and performance-intensive applications.
  • Eco-friendly design
    Compliant with RoHS standards, the Toshiba L200 Laptop PC hard drive demonstrates a commitment to environmental sustainability by minimizing the use of hazardous materials in its construction.
Toshiba L200 Laptop PC - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock sensor, Native Command Queuing (NCQ), Advanced Format technology
69.85 mm x 100 mm x 9.5 mm
117 g
3-year warranty
1 TB
2.5"
SATA 6Gb/s
Buffer Size
8 MB
69.85 mm
100 mm
9.5 mm
117 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
RoHS
Package Type
Bulk
Limited warranty - 3 years
65 °C
