Toshiba Enterprise HDD 8TB 3.5’’ SATA 6Gbit/s 7200RPM
Quicklinx: DMQPWS00 Mfr#: MG05ACA800E
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial Attached SCSI
Capacity: 8TB
Spin Speed (rpm): 7200rpm
£158.12 ex VAT
£189.74 inc VAT
The MG05ACA Enterprise Capacity HDD provides excellent capacity and great performance, in a robust design engineered for near line business-critical workloads. The MG05ACA utilizes industry-standard 3.5-inch form factor and Advanced Format sector technologies for optimum capacity and data reliability. This models support Toshiba Persistent Write Cache technology which helps enhance performance with handling data in the event of a sudden loss of power. Equipped with SATA 6.0 Gbit/s interface, the Enterprise Capacity MG05ACA models help save rack space and reduce the footprint and operational burden of business critical servers and storage systems.
Toshiba MG05ACA series MG05ACA800E - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal - nearline
8 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Halogen Free, business critical, 24x7 continuous operation, advanced format 512e, antimony free, Persistent Write Cache technology
101.85 mm x 147 mm x 26.1 mm
770 g
8 TB
3.5"
SATA 6Gb/s
Buffer Size
128 MB
101.85 mm
147 mm
26.1 mm
770 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
230 MBps
Average Latency
4.17 ms
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
24x7 Operation
Seek Errors
10 per 10^16
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
Power Consumption
6.2 Watt (active idle) , 11.4 Watt (random read)
RoHS
5 °C
55 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 90%
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Vibration Tolerance (operating)
0.75 g @ 5-300 Hz
Vibration Tolerance (non-operating)
5 g @ 5-500 Hz
Form Factor: 3.5
Type: Hard drive
Capacity: 8TB
Brand: Toshiba
