Toshiba Enterprise HDD 14TB 3.5’’ SATA 6Gbit/s 7200RPM
Quicklinx: DMQTWS00 Mfr#: MG07ACA14TE
The MG07ACA Enterprise Capacity SATA HDD provides great conventional magnetic recording (CMR) capacity and 7,200 rpm performance. The industry-standard 3.5-inch form-factor integrates easily into cloud-scale storage infrastructure, business-critical servers and storage, and File and Object storage solutions.
The MG07ACA Series utilizes Toshiba precision laser welding technology to seal helium inside the 9-disk mechanics for the life of the drive. The helium-sealed design reduces aerodynamic drag to deliver a lower operational power profile, helping to achieve TCO objectives for cloud-scale and software-defined data center infrastructure.
Toshiba Enterprise Capacity MG07ACAxxx Series MG07ACA14TE - hard drive - 14 TB - SATA 6Gb/s
Hard drive - internal - nearline
14 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
24x7 availability, Persistent Write Cache technology, Power Loss Protection (PLP), Conventional magnetic recording (CMR), Helium Sealed-Drive Design, 512 emulation ( 512e )
101.85 mm x 147 mm x 26.1 mm
720 g
14 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
720 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
248 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
24x7 Operation
Non-Recoverable Errors
10 per 10^16
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
4.22 Watt (active idle) , 7.8 Watt (random read/write)
5 °C
55 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 90% (non-condensing)
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Vibration Tolerance (operating)
0.75 g @ 5-300 Hz
Vibration Tolerance (non-operating)
3 g @ 5-500 Hz
Sound Emission
20 dBA
