Toshiba Dynadock 4K USB docking station GigE EU
Quicklinx: BQ3WWS00 Mfr#: PA5217E-1PRP
If your work demands cutting-edge detail, you'll find Toshiba's elegant dynadock 4K, with pristine Ultra HD or dual screen Full HD, the smartest way to streamline your life. With dynadock 4K you can simply plug in any notebook using a single cable - or effortlessly connect all your office and mobile needs, including your mouse, keyboard, external drives, HD TV, monitors, headphones, sound system, mobile phone and microphone. The stylish yet practical design means it can be placed vertically or horizontally, so you can keep your workspace neat and clutter-free. The dynadock 4K has six USB 3.0 ports, offering speeds up to ten times faster than USB 2.0 to ensure functionality won't be compromised - quite the opposite. Four ports are located on the back, while two are conveniently positioned on the front - complete with Sleep-and-Charge technology. That means your docked devices are fully charged and ready for action each morning. Premium Gigabit LAN ensures you have seamless network access across each device. As well as DisplayPort, the dynadock 4K also supports monitors with DVI-I or HDMI ports. That means that including the host PC monitor, the dynadock 4K enables you to use three high resolution displays at once - so you have ultimate flexibility in your media.
  • Versatile connectivity
    Equipped with a wide range of ports including USB 3.0, HDMI, DVI, and DisplayPort outputs, the Dynabook Dynadock 4K ensures seamless connection to a variety of devices and displays, making it an ideal solution for both work and entertainment setups.
  • Enhanced audio options
    With both line-in and output ports for microphones and headphones, this docking station offers enhanced audio capabilities, allowing for clear voice calls and an immersive listening experience.
  • Robust networking capabilities
    Featuring Ethernet, Fast Ethernet, and Gigabit Ethernet support, the Dynabook Dynadock 4K provides reliable, high-speed network connections, ensuring smooth data transfers and uninterrupted online experiences.
  • Convenient charging feature
    The USB Sleep-and-charge ports offer the convenience of charging external devices even when the laptop is powered down or disconnected, making it easier to keep all your devices ready to go.
  • High-definition video support
    Support for 4K video through HDMI and DisplayPort outputs allows for high-quality video streaming and gaming, turning any connected monitor into a high-end display.
Dynabook Dynadock 4K - docking station - USB - DVI, HDMI, DP - GigE
Docking station
Docking Interface
USB
Video Interfaces
DVI, HDMI, DP
8.6 cm x 13 cm x 23.1 cm
317 g
Europe
Gigabit Ethernet
Power adapter AC 120/230 V (50/60 Hz)
Toshiba Portégé A30, A30t, X20W, X30, X30T, Z20T, Z30, Z30t, Z40; Toshiba Satellite Pro A30, A40, A50, R40, R50; Toshiba Tecra A40, A50, X40, Z40, Z40T, Z50; Toshiba Portégé X20W, Z30; Satellite C70, L70, P50, P50t; Satellite Pro R50; Satellite Radius 14; 15; Tecra X40, Z50
Docking station
8.6 cm
13 cm
23.1 cm
317 g
Enclosure Colour
Europe
6 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x microphone - line-In - mini-phone 3.5 mm , 1 x headphones - output - mini-phone 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x display / video - DVI-Analog/Digital - 24+5 pin combined DVI , 1 x display / video - DisplayPort output - 20 pin DisplayPort
1 x SuperSpeed USB cable
Stand
Security lock slot (cable lock sold separately), USB Sleep-and-charge ports
Power adapter
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Dynabook Toshiba Portégé A30-C-1MG, A30-C-1MX, A30-C-1PD, A30-C-1PE, A30-C-1PW, A30-C-1PX, A30-C-1QC, A30-C-1QD, A30-C-1RF, A30-C-1RU, A30-C-1RZ, A30-C-1T6, A30-D-134, A30-D-14V, A30-D-14W, A30-D-15Q, A30-D-18T, A30-D-19R, A30-D-1C9, A30t-C-156, A30t-C-157, X20W-D-145, X20W-E-10E, X20W-E-10N, X20W-E-11X, X20W-E-120, X20W-E-13P, X20W-E-13U, X20W-E-15V, X30-D-10N, X30-D-10P, X30-D-10R, X30-D-10T, X30-D-11M, X30-D-122, X30-D-137, X30-D-138, X30-D-13W, X30-D-13X, X30-D-14W, X30-D-15H, X30-D-15L, X30-D-16E, X30-D-16Q, X30-D-173, X30-D-17J, X30-D-17K, X30-D-17L, X30-D-187, X30-D-19C, X30-D-1D3, X30-D-1FX, X30-E-11T, X30-E-11U, X30-E-12F, X30-E-12N, X30-E-12W, X30-E-133, X30-E-139, X30-E-13C, X30-E-143, X30-E-14L, X30-E-14W, X30-E-162, X30-E-179, X30-E-17F, X30-E-18X, X30-E-1DD, X30T-E-108, X30T-E-109, X30T-E-10Q, X30T-E-10X, X30T-E-110, X30T-E-112, X30T-E-11R, X30T-E-13H, X30T-E-13M, X30T-E-13R, X30T-E-148, X30T-E-14G, X30T-E-153, X30T-E-1D8, X30T-E-1DP, X30T-E-1E1, Z30-E-10X, Z30-E-114, Z30-E-12L, Z30-E-13M, Z30-E-15X, Z30-E-15Z , Dynabook Toshiba Satellite Pro A30-C-1JG, A30-D-11E, A30-D-125, A40-D-11F, A40-D-13W, A40-D-151, A50-D-150, A50-D-16W, A50-D-18V, A50-D-18W, A50-D-1J0, A50-D-1L2, A50-E-148, A50-E-14E, A50-E-16J, A50-E-16T, A50-E-1G4, A50-E-1HT, A50-E-1MZ, A50-EC-11J, A50-EC-11K, R40-C-14N, R50-C-17Z, R50-D-13K, R50-E-10V, R50-E-127, R50-E-129, R50-E-12E, R50-E-12G, R50-E-12P, R50-E-15Z, R50-E-17M, R50-E-18D, R50-E-18F, R50-E-18G , Dynabook Toshiba Tecra A40-D-12Z, A40-D-19U, A40-D-1EL, A40-D-1F2, A50-D-1E2, A50-D-1M4, A50-D-1PM, A50-D-1PR, A50-E-110, A50-E-13J, A50-E-13K, A50-E-13U, A50-E-19H, A50-E-1DJ, A50-E-1LJ, X40-D-10L, X40-D-1DT, X40-E-10Q, X40-E-10W, X40-E-10X, X40-E-115, X40-E-11M, X40-E-123, X40-E-12P, Z50-D-11Q, Z50-E-10J, Z50-E-10R, Z50-E-116, Z50-E-11F, Z50-E-14E, Z50-E-14F , Toshiba Portégé X20W-E-13J, Z30-E-12M , Toshiba Satellite Pro R50-E-12Q , Toshiba Tecra X40-E-114, Z50-E-10T, Z50-E-10Z
BQ3W C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
