Toshiba Dynabook Toshiba Satellite Pro C850-1EQ - 15.6" - Core i5 3210M - 4 GB RAM - 500 GB HDD
Quicklinx: 8DQQWS00 Mfr#: PSCBXE-01400EEN
  • Core i5
  • Windows 8 64-bit Edition
  • IEEE 802.11n
  • Bluetooth 4.0
The Satellite Pro C850 series really gets down to business with the Intel Core i5 processor. Built for value, there is a wide choice of configurations to fit your business needs. And you'll see the results in high definition and without glare on the 15.6" non-reflective HD LED screen.
QUALITY & VALUE
The new 39.6cm (15.6") Satellite Pro C850 is the perfect option for businesses looking for a combination of quality and leading value. It features a new thinner textured matt black design that prevents unwanted fingerprints on the lid, keyboard and palm-rest. Extensive connectivity options are incorporated and include SuperSpeed USB 3.0, HDMI and an integrated numeric keypad for added convenience and ease of use. Available in a wide range of affordable configurations.
  • Choose to perform
    Whether you're growing a business or have already hit the big time, you will appreciate having the powerful processor, memory sizes and external graphics. This model will give you the peace of mind of having equipped your team with reliable, budget-friendly laptops that are a joy to work on.
  • The bottom line
    The C850 comes with a non-reflective LED screen, webcam, full numeric keypad and fast connectivity as standard. Like all Toshiba laptop, the Satellite Pro C850 series is engineered and tested for reliability, speed and performance.
  • Great connections
    They have given the C850 a good dose of fast, up-to-date connectivity options. If you need to transfer large files on your network quickly, then you'll love the built-in Gigabit LAN adapter. If fast transfers from your storage devices are vital, then USB 3.0 will give speeds up to 10x faster than USB 2.0. Built in Bluetooth means you can sync your mobile devices without a cable and make video calls with a wireless headset.
  • Comfort engineering
    To keep you and your staff relaxed and effective throughout the day, the C850 series comes with comfort built in. This starts with a non-glare LED screen that is easy on the eyes. There is a full numeric keypad next to the spacious keyboard. Thanks to the high-definition webcam with face recognition, logging in is simple and video conferences are crystal clear.
Dynabook Toshiba Satellite Pro C850-1EQ - 15.6" - Intel Core i5 3210M - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 8 64-bit
Intel Core i5 (3rd Gen) 3210M / 2.5 GHz (3.1 GHz) / 3 MB Cache
4 GB DDR3 (1 x 4 GB)
Storage
500 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4000
Numeric Keypad
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
Up to 5.5 hours
Matt black with textured pattern, black keyboard
38 cm x 24.2 cm x 3.352 cm
2.3 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Enhanced SpeedStep technology, Hyper-Threading Technology, Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3 SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Max Allocated RAM Size
1696 MB
Camera
Resolution
1 Megapixel
Video Resolutions
1280 x 800
Sound
Stereo speakers, microphone
Codec
Realtek ALC269Q
High Definition Audio, SRS Premium Sound HD
Input
Keyboard, touchpad
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
Lithium Ion
48 Wh
Run Time
Up to 5.5 hours
AC Adapter
Input
Output
65 Watt, 19 V, 3.42 A
Connections & Expansion
USB 3.0 , LAN , VGA , Headphone output , HDMI , 2 x USB 2.0 , Microphone input
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Toshiba TEMPRO Performance Tuning Service, McAfee Internet Security Suite (30 days subscription), Microsoft Office (Trial), Toshiba PC Health Monitor, Toshiba Recovery Media Creator, Toshiba Eco Utility, Toshiba Service Station, Toshiba Media Player, Toshiba Password Utility, Toshiba Video Player, Toshiba Places, Toshiba Resolution+, SRS Premium Sound HD, Nero 12 Essentials, Intel AppUp Center, McAfee Security Advisor, Microsoft Fresh Paint, Microsoft Solitair Collection, Toshiba Function Keys, Toshiba Desktop Assist, Toshiba System Settings
Case Material
Polycarbonate ABS
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Intel Rapid Storage Technology
Power adapter
Localization
2.3 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 90%
