Toshiba Dynabook Satellite Pro R50 Core i3-7020U 8GB 128GB SSD 15.6" Windows 10 Pro Academic 64-bit
Quicklinx: FGXVWS00 Mfr#: PS591E-0P802VEN
  • Core i3
  • IEEE 802.11n
The Satellite Pro R50 has been designed specifically to meet the requirements of professionals. The device offers a solid combination of performance and reliability - backed up by Toshiba's history in notebook development. Designed to be a reliable companion in the business environment, the Satellite Pro R50 has a keyboard that can withstand heavy daily use, and a 3D sensor for data protection. Built to work straight out of the box, the Satellite Pro R50 reaches maximum performance without relying on external peripherals. With the Intel Core architecture, Wi-Fi and LAN capabilities, the device single-handedly delivers on every professional demand.
  • Professional performance
    The Satellite Pro R50-E is designed specifically to meet the requirements of professionals. It offers a solid combination of performance and reliability, along with a keyboard that can withstand heavy daily use. Plus, it has a 3D sensor for data protection and is drop tested* to ensure its ruggedness.
  • Long term value
    It's a cost effective device that professionals can rely on, as the device has been built to last. You can feel reassured by a solid design that's built to withstand the pressures of daily use – with a selection of the latest features that won't date quickly.
  • The standalone solution
    It's built to work straight out of the box and reaches maximum performance without relying on external peripherals. It single-handedly delivers on every professional demand: the complete system supports silent working, while a full size keyboard adds convenience and comfort.
  • Premium without the price tag
    With premium components housed in a highly resistant body, the Satellite Pro R50-E is built to handle the most demanding professional environments. The device is secured with a Kensington lock slot to protect your laptop.
  • Connected to your business needs
    The Satellite Pro R50-E is well connected, so you can save, store and share data easily. With HDMI, RGB, USB 3.0 and LAN, connecting to peripherals is simple. Plus, there's an SD card slot which enables you to rapidly export data when required.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Satellite Pro R50-E-18V - 15.6" - Core i3 7020U - 8 GB RAM - 128 GB SSD
Notebook
Operating System
Windows 10 Pro National Academic
Intel Core i3 (7th Gen) 7020U / 2.3 GHz / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
128 GB SSD
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell - up to 9.75 hours
3-axis accelerometer
Security
Trusted Platform Module (TPM 2.0) Security Chip
Graphite black, black (keyboard)
37.9 cm x 25.8 cm x 2.395 cm
2 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
128 GB SSD M.2 SATA
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - HD
Resolution
0.9 Megapixel
Video Resolutions
1280 x 720
Sound
Stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, touchpad
Numeric Keypad
Multi-gesture touch pad, automatic palm detection
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 9.75 hours
AC Adapter
Input
AC 120/230 V
Output
19 V, 2.37 A
Connections & Expansion
4 x USB 3.0 , VGA , HDMI , Headphone/microphone combo jack , LAN
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Microsoft 365 (30 days trial), DTS Sound
Integrated Options
Security
Administrator password, system password, hard drive password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
2 kg
ENERGY STAR Certified
