The Satellite Pro R40 is a device designed to meet the demands of business professionals who need dependability, and students who require a sturdy learning companion. Well-equipped with a powerful processor, users have all they need to be productive.
A professional device that just works
The Satellite Pro R40-C is an entry-level device, designed to meet the demands of business professionals who need a dependability, and students who require a sturdy learning companion. Well-equipped with Intel Core architecture – and with the option to include Windows 10 Pro – users have all they need to be productive. And it's all backed up by Toshiba's 30 years of notebook development and innovation. -
Stands up to the rest of daily use
Designed to withstand the daily wear and tear of an education environment – or the demands of a busy office – the Satellite Pro R40-C offers longevity and reliability. Its 3D sensor helps to keep data protected at all times, and its robust chassis design has passed vigorous hinge testing to ensure sturdiness over a prolonged period of time. -
Ergonomically designed for professional performance
The Satellite Pro R40-C's full size keyboard delivers a professional typing experience for optimised productivity. Its silent functionality means it's easy to work discreetly in important meetings, quiet libraries or on crowded trains. And the non-CSV screen enables users to work indoors or outdoors – in both low light and bright light scenarios – without distraction. -
Connects to all the essentials
Users can enjoy full connectivity, without the need for any adapters, thanks to a selection of full-size ports including: HDMI, RGB, USB 3.0, Gigabit LAN and SD-card. The Satellite Pro R40-C also comes equipped with the latest wireless technologies, such as the Intel premium ac/abgn, Intel Wireless-Display and Bluetooth – meaning business professionals and students alike can always connect to everyone and everything they need to. -
Balances quality and affordability
Offering the right balance between high quality components – such as a reliable Intel Core architecture, Intel Premium Wi-Fi and Gigabit LAN – and affordable price points, the Satellite Pro R40-C is perfectly positioned for budget-conscious students and young business professionals. The device is also ideal for businesses with multiple orders to make – providing a reliable foundation for any office. -
Compatible with an array of accessories
The Satellite Pro R40-C has all the single plug-and-click connection points users need to connect to all kinds of peripherals and displays. This includes Toshiba's Dynadock and storage range – which helps to make the device a comprehensive desktop companion. What's more, users can make the most of Toshiba's compatible bags and sleeves for carrying and protecting their device. *Accessories sold separately. Please check the range of accessories available at. -
Optimises power consumption
Users are able to stay in control of the Satellite Pro R40-C's power consumption, thanks to Toshiba's pre-installed Eco Utility software. In fact, the EPEAT certified device is eco-friendly in every aspect, also benefitting from the latest Energy Star qualification. -
Services for a flawless performance
The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
- Dynabook Toshiba Satellite Pro R40-C-164 - 14" - Core i3 6006U - 4 GB RAM - 128 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i3 (6th Gen) 6006U / 2 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 128 GB SSD
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 8 hours
- Accelerometer
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Cosmo Silver, tile black (keyboard)
- 34.01 cm x 24.41 cm x 2.38 cm
- 1.75 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - pick-up and return - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD M.2 SATA
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Resolution
- 0.9 Megapixel
- Video Resolutions
- 1280 x 720
- Sound
- Stereo speakers, two microphones
- DTS Studio Sound
Input
- Keyboard, touchpad
- Multi-gesture touch pad, Palm Rejection Technology
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V
- Output
- 19 V, 2.37 A
Connections & Expansion
- 2 x USB 3.0 ¦ LAN ¦ VGA ¦ HDMI ¦ Headphone/microphone combo jack ¦ USB 3.0 (Sleep & Charge)
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription)
- Integrated Options
- Accelerometer
- Security
- Administrator password, system password, hard drive password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.75 kg
- ENERGY STAR Certified
