The Portégé X30 powers through your workload with powerful CPU, and doesn't overheat, thanks to Hybrid Air Cooling technology - so everything runs fast, and runs smoothly, even in a sleek and light chassis.
Power in a slim package
At 15.9 mm thin and 1.05 kg light, the Portégé X30-F helps you power through any task, anywhere. The innovative Intel Optane SSD shortens waiting times and speeds up your output, while the latest Intel Wi-Fi modules connect using 802.11ax for improved security, higher throughput and improved network capacity. The Portégé X30-F can always keep up too: its new S-Type cooling system works tirelessly and quietly to protect against overheating. -
Work with confidence
We built the Portégé X30-F with security at its core – and our own unique in-house BIOS is the foundation. With two-factor authentication, including IR-based Windows Hello and fingerprint reader, this machine is easy to access in the right hands, and almost impenetrable in the wrong ones. Wake the Portégé X30-F up instantly using the wake on fingerprint feature, then access information straight away - without having to wait to reconnect - thanks to modern standby. -
The world is your office
When you're working on the move, you need a laptop that can keep up. That's why we equipped the Portégé X30-F with a FHD non-reflective screen including optional In-Cell Touch technology – so whatever the lighting conditions, you can access content fast and watch it with clarity. You can connect on the go too, with optional mobile broadband including LTE. -
The tools to achieve
If you're a high performer, the Portégé X30-F is your perfect partner. Its sturdy honeycomb-structured magnesium chassis is armed with the latest technology – including twin USB Type-C Thunderbolt 3 enabled ports for extendable connectivity. Meanwhile the blistering fast Intel Optane SSD drive with up to 1 TB of space gives you the power you need to fulfil your potential. -
Immaculate presentation
The way you present content to your peers, clients and managers can make all the difference. So we added Harman/Kardon speakers with DTS for crisp sound that helps everyone in the room hear you loud and clear. And with an HDMI port that allows you to share on-screen content with a larger display or TV, they'll have a crystal-clear view too. -
Services for a flawless performance
The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
- Dynabook Toshiba Portégé X30-F-12M - 13.3" - Intel Core i7 - 8565U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (8th Gen) - 8565U / 1.8 GHz, up to 4.6 GHz / 8 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 13.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- AccuPoint, SecurePad
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- 3-cell - up to 10.5 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Tile matte black (keyboard), onyx blue with hairline
- 31.6 cm x 22.7 cm x 1.64 cm
- 1.05 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Bundled Services
- 1 Year Reliability Guarantee
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8565U / 1.8 GHz
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Intel Turbo Boost Technology
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 470 cd/m²
- Anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Camera Features
- IR camera, Windows Hello
- Sound
- Harman/kardon stereo speakers, two microphones
- DTS Studio Sound
Input
- Keyboard, AccuPoint, SecurePad
- Glass finished Securepad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Run Time
- Up to 10.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , HDMI , USB 3.0 (Sleep & Charge) , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery/data/video)
Software
- Software Included
- Microsoft 365 (30 days trial)
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- Localization
- 1.05 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
