The Portégé X30-E runs fast and smoothly, even in a sleek and light chassis. The Portégé X30-E is equipped with a non-reflective touchscreen and IPS technology, which enables you to navigate and interact with content without compromising on the slim design of the device or the clarity of the display.
Made with pride
The Portégé X30-E is just 15.9 mm thin and 1.05 kg in weight but it can power through your workload with your choice of up to an 8th generation Intel Core processor. And it doesn't overheat, thanks to our new Hybrid Air Cooling technology – so everything runs fast, and runs smoothly, even in a sleek and light chassis. -
Security, assured
Built on our own unique in-house BIOS, we've added two-factor authentication - including IR-based Windows Hello and built-in fingerprint reader - to the security features of the Portégé X30-E. It's the device you can trust with an optional Toshiba Slim cable lock for physical security. -
For however you work
We build everything with you in mind. The Portégé X30-E is equipped with a non-reflective touchscreen and brand new In-Cell Touch technology, which enables you to navigate and interact with content without compromising on the slim design of the device or the clarity of the display. Connect on the go with optional mobile broadband including LTE. -
Productivity unleashed
We have packed the Portégé X30-E with the latest high performance technology. In this honeycomb-structured magnesium design you will find your choice of up to an 8th generation Intel Core processor and twin USB Type-C Thunderbolt 3 enabled ports for extendable connectivity. A blistering fast PCIe SSD drive with up to 1TB of space completes the picture. -
Content that fills a room
The Portégé X30-E is equipped with Harman/Kardon speakers with DTS that give you crisp sound, clear music and video audio that really fills a meeting room. The HDMI port means you can share on-screen content on a larger display or TV. -
Services for a flawless performance
The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
- Dynabook Toshiba Portégé X30-E-133 - 13.3" - Intel Core i7 - 8550U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (8th Gen) - 8550U / 1.8 GHz, up to 4 GHz / 8 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 256 GB SSD
- Display
- 13.3" 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- AccuPoint, SecurePad
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell - up to 10.16 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Matte black (keyboard), onyx blue with hairline
- 31.6 cm x 22.7 cm x 1.64 cm
- 1.05 kg
- Localisation
- Region: United Kingdom, Ireland
- Environmental Standards
- ENERGY STAR Qualified
- EMEA warranty - 1 year - carry-in
- Bundled Services
- 1 Year Reliability Guarantee
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8550U / 1.8 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD M.2 PCIe
Display
- 13.3"
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Camera Features
- IR camera, Windows Hello
- Sound
- Harman/kardon stereo speakers, two microphones
- DTS Studio Sound
Input
- Keyboard, AccuPoint, SecurePad
- Glass finished Securepad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Run Time
- Up to 10.16 hours
AC Adapter
- Input
- AC 120/230 V
- Output
- 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.0 (Sleep & Charge) , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery/data/video) , HDMI
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Microsoft 365 (30 days trial)
- Security
- Intel Authenticate
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- USB-C power adapter
- Localization
- 1.05 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
