Toshiba Canvio Slim for Mac 1TB USB 3.0 2.5" Hard Drive - Silver
Quicklinx: B43GWS00 Mfr#: HDTD210ESMEA
Store data securely on the new Canvio Slim For Mac external hard drives. Its elegant slim and lightweight design makes it a perfect companion for your Mac®. Compatible with Apple® Time Machine®, you can back-up your data easily. Transfer your files via SuperSpeed USB 3.0 and keep them safe using a password lock.
Extra slim, extra portable
With a super slim design that looks good and is light enough to carry anywhere, you will want to store and share your data securely wherever you go.
Compatible with Apple Time Machine
Your portable hard drive works with Apple® Time Machine®, making it easier to back-up all the data on your Mac® at home or when you're out and about.
SuperSpeed USB 3.0 for faster transfers
Powered by new USB 3.0 technology, Canvio Slim For Mac® is far faster than—but still compatible with—USB 2.0 technology. That's important for speedy transfer when organising your files.
Safely locked away
Lock your Canvio Slim For Mac® with a password that's unique to you - and prevent unauthorised users from accessing important data stored on your hard drive.
Toshiba StorE Slim for MAC - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication
Power Source
USB bus
Enclosure Colour
Silver
Bundled with
10GB free Cloud Backup
1 TB
2.5"
USB 3.0
Bundled with
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Software Included
NTI Backup NOW! EZ, Tuxera HTFS
Enclosure Colour
Silver
