Toshiba C50-A-1E2 15.6" Intel Core i3 3110M 2.4GHz 4GB 500GB DVD HDMI USB3 Windows 8.1
Quicklinx: 9361WS00 Mfr#: PSCG7E-02C041EN
  • Core i3
  • Windows 8.1 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
The Toshiba 15.6" C50 Core i3 Laptop
When you consider a laptop purchase it worth while to consider how well built tha laptop is and Toshiba have always been known for high quality. This build ethic is also backed up in this laptop with a seriously powerful Intel Core i3 3110m 2.4GHz processor and 4GB ram. When you add this to the massive amount of ways to connect including: Bluetooth, HDMI and USB3 then you really have a best in class machine in the mid/high range category.
Well Connected
Toshiba laptops come with a range of features and connectivity options that enhance your user experience. The spacious full size keyboard with numeric keypad is ideal for applications such as spreadsheets, and ensures typing is comfortable. Swap pictures and files or expand your storage capabilities using the SD card slot, plug into the 1x USB 3.0 or 2x USB 2.0 ports to share content with your other devices. USB 3.0 is the latest USB standard that offers transfer rates up to 10 times faster than Hi-Speed USB 2.0. HDMI connectivity enables high definition connectivity from your laptop to AV equipment including your HD TV.
Streamlined Design
The Satellite C50 features a new streamlined design with a textured matt black finish and weighs from only 2.4kg. The textured finish helps to minimise fingerprint marks as well as giving a smart look and feel. The 39.6cm (15.6") display with LED backlighting delivers sharp and vivid images.
High Quality Audio
The integrated stereo speakers are positioned below the screen and combine with DTS Sound audio suite to ensure that music or movie soundtracks can be enjoyed at their best. DTS Sound includes a sound enrichment suite that boosts volume, enhances bass and improves definition. Enjoy immersive audio complete with deep, rich bass and crystal clear dialogue. DTS Sound also delivers high-frequency definition for crisp detail in any listening environment, ensuring users a premium and natural entertainment experience whether you are using the laptop speakers or headphones.
MAIN FEATURES
  • Processor: Intel Core i3 3110M (2.4GHz, 2MB Cache)
  • Screen: 15.6" (Toshiba TruBrite TFT, 1366x768 WXGA resolution, LED Backlight)
  • RAM 4GB: (DDR3)
  • Hard Drive: 500GB
  • Optical Drive: DVD Rewriter (Records DVDs 8x & CDs 24x & Dual Layer Super Multi)
  • Graphics: Integrated (Intel HD Graphics)
  • Wireless LAN: Wireless (802.11a/b/g/n Wireless)
  • Network Card: 10/100/1000 Gigabit Fast Ethernet
  • Features: WEBCAM , CARD READER (SD/SDHC,MMC) , BLUETOOTH 4.0
  • Ports : 2x USB 2.0, 1x USB 3.0 , HDMI, VGA
  • Speakers: Integrated Sound System
  • OS: Win8
  • Warranty: 12 Months
  • Built for your business
    Whatever the size and nature of your business, there's a Satellite Pro C50-A for you. With Core i3 processor, you can create the ideal business laptop for your everyday needs. And because C50-A delivers a reliable performance at an affordable price, you get plenty of added value every time you use it.
  • Smarter investment
    With a proven reputation for business laptops, the Satellite Pro range is the professional's choice. And you can see why, when dedicated business features, higher speeds and an efficient performance come as standard. Add to that Toshiba quality you can count on, and the reasonably-priced C50-A becomes a really smart investment.
  • Maximum flexibility
    The C50-A is versatile, in and out the office. You have a choice of USB 2.0 and USB 3.0 ports to transfer data to your storage devices. And you can zip it there up to 10 times faster using USB 3.0. With HDMI, you have the flexibility to share your work on display devices. And you get the wireless freedom to sync your mobile devices too, with Bluetooth 4.0 built in.
  • Consistently reliable
    You rely on your business laptop. So you need to know that it will perform, day after day. With the Intel Core i3 processor, the C50-A delivers a consistently powerful performance, from boot-up to shut-down.
  • Commercial comfort
    If you're looking to combine comfort with productivity, then the C50-A has all the answers. You can expect amazing picture quality with no harsh glare from the non-reflective 39.6 cm (15.6") HD LED backlight display. And an improved full-size keyboard with a useful numeric keypad, for faster number-crunching.
Dynabook Toshiba Satellite Pro C50-A-1E2 - 15.6" - Intel Core i3 3110M - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 8.1 64-bit
Intel Core i3 (3rd Gen) 3110M / 2.4 GHz / 3 MB Cache
4 GB DDR3 (1 x 4 GB)
Storage
500 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4000
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
Up to 3.5 hours
Matt black with hairline pattern, black keyboard
38 cm x 24.2 cm x 3.335 cm
2.3 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Windows 8.1 64-bit Edition (preloaded)
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Enhanced SpeedStep technology, Hyper-Threading Technology
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3 SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Max Allocated RAM Size
1771 MB
Camera
Resolution
0.9 Megapixel
Video Resolutions
1280 x 720
Sound
Stereo speakers, microphone
Codec
Realtek ALC269Q
High Definition Audio, DTS Sound
Input
Keyboard, touchpad
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
Lithium Ion
48 Wh
Run Time
Up to 3.5 hours
AC Adapter
Input
Output
65 Watt, 19 V, 3.42 A
Connections & Expansion
2 x USB 3.0 , LAN , VGA , Headphone output , HDMI , USB 2.0 , Microphone input
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Toshiba Media Player, Toshiba Function Keys, Toshiba Desktop Assist, Toshiba System Settings, Microsoft 365 (30 days trial), Toshiba Display Utility, DTS Sound, McAfee LiveSafe (30 days subscription)
Case Material
Polycarbonate ABS
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN
Power adapter
Localization
2.3 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 90%
