Toshiba AC Adapter 19v DC
Quicklinx: 69H7WS00 Mfr#: PA3715E-1AC3
Universal AC adapter is designed to power your notebook through your home or office electric socket. Toshiba's universal AC adapters can be used anywhere in the world with the appropriate AC plug adapter.
Toshiba - power adapter - 75 Watt
Power adapter - external
310 g
Input Voltage
AC 100-240 V
Output Voltage
19 V
Power Capacity
75 Watt
Output connectors
1 x power DC jack
12.7 cm x 3.1 cm x 5.1 cm
Satellite A500, A660, A665, C650, C650D, C660, C670, C855, L550, L630, L650, L730, L735, L750, L755, L770, L770D, L775, P750, P750D, P770, P770D, T110, T130, U400
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
1 x power DC jack
Output Voltage
19 V
Max Electric Current
3.95 A
Power Capacity
75 Watt
No power cord is included
TUV GS, PCT, CCC, cULus
12.7 cm
3.1 cm
5.1 cm
310 g
Toshiba Satellite A665-S5173, A665-S5183X, A665-SP5161M, A665-SP6011M, C650-00P, C650-BT4N12, C650D-005, C650D-032036, C660-162, C660-19T, C660-1KG, C660-1LG, C660-1LH, C660-1LK, C660-1LL, C660-1ME, C660-1MF, C660-1MG, C660-1MK, C660-1NF, C660-1NW, C660-1P7, C660-1P8, C660-1PD, C660-1PZ, C660-1RK, C660-1T9, C660-1TM, C660-1U0, C660-1U6, C660-1WM, C660-1WN, C660-1WV, C660-1WW, C660-1WX, C660-1WZ, C660-1X0, C660-1X1, C660-1X2, C660-1X4, C660-1X5, C660-1X6, C660-1X7, C660-1X9, C660-1XT, C660-1ZU, C660-21J, C660-21K, C660-21W, C660-21Z, C660-225, C660-226, C660-227, C660-22C, C660-22Q, C660-22W, C660-23K, C660-246, C660-249, C660-24C, C660-258, C660-25U, C660-264, C660-26G, C660-26X, C660-28D, C660-28R, C660-28T, C660-28V, C660-2CR, C660-2D7, C660-2DL, C660-2DV, C660-2E1, C660-2E2, C660-2E3, C660-2EL, C660-2F2, C660-2FD, C660-2FE, C660-2G6, C660-2KW, C660-2L0, C660-2N3, C660-2Q7, C660-2QH, C660-2T6, C660-2T7, C660D-1EH, C670-104, C670-189, C670-19E, C670-1D5, C670-1DC, C855-15Q, C855-192, L650-10L, L730, L730-02K, L730-106, L730-10U, L730-10V, L730-10X, L730-117, L735-142, L750, L750-065, L750-070, L750-10N, L750-114, L750-118, L750-11K, L750-12U, L750-12W, L750-12Z, L750-148, L750-16J, L750-16L, L750-16V, L750-16W, L750-16X, L750-16Z, L750-170, L750-171, L750-176, L750-17D, L750-17N, L750-17P, L750-18R, L750-1DH, L750-1DJ, L750-1DK, L750-1DL, L750-1DM, L750-1DQ, L750-1DR, L750-1DU, L750-1DV, L750-1DW, L750-1DX, L750-1E5, L750-1E8, L750-1E9, L750-1EK, L750-1EZ, L750-1HR, L750-1KU, L750-1LC, L750-1RJ, L750-1RP, L750-1VV, L750-1VW, L755-1LQ, L770, L770-00R, L770-00S, L770-117, L770-119, L770-11U, L770D-00Q, L770D-10G, L770D-10H, L770D-ST4N01, L775-17H, P750, P750-00Y, P750-010, P750-04S, P750-04X, P750-10E, P750-10T, P750-11H, P750-121, P750-12T, P750-12U, P750-133, P750-13F, P750-13G, P750-13L, P750-13M, P750-13N, P750-15G, P750D, P770, P770-00K, P770-10G, P770-115, P770-116, P770-117, P770-118, P770-11G, P770-11M, P770D
