The FlashAir SD card features an advanced processor design and delivers enhanced wireless performance as well as standard SD memory card functionality. Now it has even greater flexibility thanks to the integrated Eyefi Connected feature that prevents a camera automatically powering off when wirelessly connecting with FlashAir. Built-in wireless LAN functionality allows data stored on the card to be transferred to external devices.
Easy wireless LAN setup
You do not need any drivers, software or cables. Just slide your FlashAir SD card into your camera or camcorder and setup the wireless LAN function using a PC, tablet or smartphone. -
Low power consumption
Optimized for battery powered devices, the wireless function is switched ON only when necessary, keeping the power consumption low.
- Toshiba FlashAir W-04 - wireless memory card - 64 GB - SDXC
- Product Type
- Wireless memory card
- Form Factor
- SDXC Memory Card
- Interface Type
- IEEE 802.11 b/g/n
- Storage Capacity
- 64 GB
- Speed Rating
- UHS-I U3 / Class10
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, WEP
- OS Required
- Apple MacOS X 10.7 - 10.10, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
- 5-year warranty
- Product Type
- Storage Capacity
- 64 GB
- Speed Class
- Form Factor
- SDXC Memory Card
- Interface Type
- IEEE 802.11 b/g/n
- X-ray-proof, Wireless LAN Access Point mode (WLAN AP), Eyefi Connected
- OS Required
- Limited warranty - 5 years
- 24 mm
- 2.1 mm
- 32 mm
- 2 g
- -25 °C
- 85 °C
