Toshiba 64GB Exceria N302 SD Card
Quicklinx: CBFSWS00 Mfr#: THN-N302R0640E4
Put the Toshiba N302 memory card in your digital camera or your mobile device and expand your storage. You can take many pictures with your smartphone or store songs and videos.
  • Capture your precious moments
    Great for enthusiastic photographers, this memory card provides the speed and capacity you need to catch the perfect moment in Full HD.
  • Secure your files
    With the Toshiba write-protect feature, you can prevent accidental overwrites. Also, no worries at the airport security check, the card safely protects your precious memories from the radiation of the security scanners.
Toshiba EXCERIA N302 - flash memory card - 64 GB - SDXC UHS-I
Flash memory card
SDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
UHS-I U3 / Class10
5-year warranty
Flash memory card
Storage Capacity
64 GB
Speed Class
UHS-I U3 / Class10
Read Rate
Up to 90 MB/s
Limited warranty - 5 years
24 mm
32 mm
2.1 mm
2 g
