Toshiba 64GB Exceria M302 microSD Card with adaptor Class 10 4K 90MB/s
Quicklinx: C5CZWS00 Mfr#: THN-M302R0640EA
EXCERIA™ M302
The speed you need for 4K
A Toshiba EXCERIA™ M302 is the microSD™ card you need if you want to record 4K or Full HD videos on your smartphone, tablet or sports camera. Designed for outdoor usage, the series is waterproof, shockproof and x-ray proof. Because of the fast read-write speeds, you get smooth video recording, quick loading of apps and fast continuous photography. To round out the picture, the EXCERIA™ M302 comes with an SD card adaptor so you can quickly transfer and share your valuable memories.
RECORD AND PLAY IN 4K AND FULL HD
Due to ultra-fast read speeds and large capacity, the EXCERIA™ microSD™ card series is designed for 4K and Full HD video recording and rapid image capture.
ADVENTURE CALLING
Incredibly small, the series is ideal for owners of smartphones, tablets and sports and action cameras who are serious about their videos and photography.
WORK UNDER TOUGH CONDITIONS
Since the cards were specifically designed for outdoor video recording and photography, we made sure they will perform under extreme conditions. That's why they are shockproof and waterproof.
CATCH SOME RAYS
No worries at the airport security check or at your sunny vacation destination. The cards are x-ray proof to protect your precious memories.
STORE MORE MEDIA
Adding a microSD™ card lets you store more of your favourite media. For example, with 128 GB you can store 1,920 minutes of video, 30,500 photos or 960 hours of music - all in high quality.
QUALITY YOU CAN TRUST
Toshiba is the inventor of flash memory, and has a well-earned worldwide reputation for producing high quality technology.
  • Capture and carry with you
    Record all your exciting moments with your smartphone or digital camera. With a huge capacity you can keep all your pictures and Full HD videos with you without having to delete some of your precious moments.
  • Capture your precious moments
    Great for enthusiastic photographers, the EXCERIA microSD M302 card series provides the ultra-fast speed and capacity you need to catch the perfect moments in Full HD.
  • Secure your files
    With the Toshiba write-protect feature, you can prevent accidental overwrites.
Toshiba EXCERIA M302-EA - flash memory card - 64 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
UHS Class 3 / Class10
Included Memory Adapter
microSDXC to SD adapter
5-year warranty
Flash memory card
Storage Capacity
64 GB
Speed Class
Read Rate
Up to 90 MB/s
Shockproof, waterproof, X-ray-proof
Limited warranty - 5 years
11 mm
15 mm
Thickness
1 mm
0.4 g
-25 °C
85 °C
