Quickly transfer files with SuperSpeed USB 3.0 and store up to 500 GB of data on STOR. E BASICS external drives. Easy to use and backward compatible with USB 2.0, STOR. E BASICS external drives are ready to use with no software installation required.
The Toshiba STOR.E Basics 2.5 Inch 500GB external hard drive makes super speed storage simple. Receive high speed storage via the USB 3.0 port, allowing you to store your data with super speed. Enjoy high capacity storage of up to 500GB in a conveniently compact casing.
- Interface type USB 3.0 (USB 2.0 compatible)
- Interface Transfer rate max. 5.0 Gbps
- On-bus power max. 900 mA
- Dimensions (mm) 118.9 (L) x 79 (W) x 13.5 (H) mm
Box content
- 500GB STOR.E Basics
- USB 3.0 cable ("A" to Micro "B")
- Quick Start Guide
- Warranty Leaflet
- pre-installed User Manual
- Toshiba StorE BASICS - hard drive - 500 GB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Ramp Load
- Power Source
- USB bus
- Enclosure Colour
- Matte black
- 7.9 cm x 11.9 cm x 1.4 cm
- 150 g
- Designed For
- Dynabook Toshiba Portégé R830, R930, Z830, Z930; Toshiba Tecra R940, R950; Toshiba LX830; NB510; NB520; Qosmio F750, X770, X870; Satellite C660, C670, C850, C850D, C855, C855D, C870, C870D, C875, C875D, L730, L735, L750, L750D, L755, L755D, L775, L775D, L830, L850, L850D, L855, L855D, L870, L870D, L875, L875D, L950D, L955, L955D, P750, P770, P845T, P850, P855, P870, P875, R830, R930, S70, U840, U840W, U920t, U940, Z830, Z930
- Capacity
- 500 GB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Ramp Load
- 7.9 cm
- 11.9 cm
- 1.4 cm
- 150 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- OS Required
- Microsoft Windows 7
- Cables Included
- 1 x USB 3.0 cable - external
- Plug and Play
- Enclosure Colour
- Matte black
- Designed For
- Dynabook Toshiba Portégé R930-14X, R930-18L, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, R930-1FU, R930-1FV, Z930-13M, Z930-14D, Z930-153 , Dynabook Toshiba Tecra R940-1GQ, R940-1JF, R940-1JG, R940-1JH, R940-1L0, R940-1L1, R950-176, R950-1EJ, R950-1EK, R950-1EL, R950-1EM, R950-1EN, R950-1JH, R950-1JJ , Toshiba LX830-11G , Toshiba Qosmio X870-13U, X870-140, X870-141, X870-142, X870-15K , Toshiba Satellite C850-1DV, C850-1DW, C850-1F2, C850-1GL, C850-1JV, C850-1JZ, C850-1KM, C850-1KR, C850-1LH, C850-1LW, C850-1LX, C850-1M8, C850-1MC, C850D-115, C850D-121, C850D-12L, C850D-12V, C855-1TH, C855-1VX, C855-1WZ, C855-1XC, C855-1XD, C855-1XE, C855-20N, C855-20P, C855-21V, C855-21W, C855-253, C855-25L, C855-27L, C855-28U, C855-29L, C855-29M, C855-29N, C855-2EE, C855-2EF, C855-2EJ, C855-2ET, C855-2EU, C855-2EZ, C855-2F0, C855-2F1, C855-2F2, C855-2F3, C855-2F7, C855-2F8, C855-2F9, C855-2FC, C855-2FN, C855-2FP, C855-2FQ, C855D-12P, C855D-13J, C855D-150, C855D-15U, C855D-15W, C855D-15Z, C870-17T, C870-18C, C870-18M, C870-19H, C870-1CH, C870-1D2, C870-1EW, C870-1F3, C870-1FE, C870-1GF, C870-1GW, C870-1GZ, C870-1H0, C870-1H2, C870-1HE, C870D-117, C870D-119, C870D-11E, C870D-11F, C870D-11P, C870D-11T, C870D-11V, C870D-11X, C870D-11Z, C870D-120, C875-114, C875-150, C875D-10E, L830-13J, L830-13K, L830-14G, L830-15G, L830-15H, L830-15J, L830-15L, L830-160, L830-164, L850-1K1, L850-1K8, L850-1KG, L850-1Q2, L850-1TE, L850-1V0, L850-1V1, L850D-12T, L855-14K, L855-15L, L855-15U, L855-179, L855-17Q, L855-17R, L855D-10G, L855D-10H, L855D-10J, L855D-10K, L870-182, L870-18K, L870-18Q, L870-18V, L870D-10N, L870D-10V, L870D-10W, L875-12V, L875-132, L950D-100, L955-108, L955-10F, L955-10J, L955D-104, L955D-107, L955D-10F, P845t-103, P845t-104, P845T-108, P845t-10G, P845t-10J, P850-31W, P850-31Z, P850-32M, P850-32Z, P855-33X, P855-34P, P870-31G, P870-320, R930-1CV, S70-B-10F, U920t-10F, U920t-117, U920t-11C, U940-104, U940-11N, Z930-13C
