The MQ01ABF series has been engineered to deliver high performance, combined with low energy consumption efficiency in Ultrabooks and high-end multimedia devices with data intensive applications.
Forming part of a series of advanced format technology HDDs, the MQ01ABF032 is developed to deliver a higher internal transfer rate with industry-leading recording density, making it ideally suited to media intensive applications. It is free from halogen, antimony trioxide and red phosphorus.
- Toshiba MQ01ABF032 - hard drive - 320 GB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 320 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 8 MB
- Spindle Speed
- 5400 rpm
- 69.85 mm x 100 mm x 7 mm
- 92 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 320 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 8 MB
- Bytes per Sector
- 4096
- 69.85 mm
- 100 mm
- 7 mm
- 92 g
Performance
- Seek Time
- 22 ms (max)
- Track-to-Track Seek Time
- 2 ms
- Spindle Speed
- 5400 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 1.5 Watt (active) , 0.55 Watt (idle)
- RoHS
- 5 °C
- 55 °C
- Shock Tolerance
- 400 g @ 2ms half-sine pulse (operating) / 900 g @ 1ms half-sine pulse (non-operating)
- Vibration Tolerance
- 1 g @ 5-500 Hz (operating)
- Sound Emission
- 21 dB
