Toshiba 32" High Definition Smart LED TV with Freeview HD
Quicklinx: 9G0RWS00 Mfr#: 32W3451DB
  • FREEVIEW HD
  • DVB-T
With striking style and picture performance, the Toshiba 32" W3451DB TV delivers the combination of high definition image projection with high quality audio reproduction for a truly immersive entertainment experience.
You can expand your entertainment capabilities furthermore with Smart technology, giving you access to a wide range of content that works alongside Wi-Fi connectivity to bring you on-demand movies, TV and videos courtesy of BBC iPlayer, Netflix, YouTube and others. There is even a built-in Freeview HD tuner that gives you access to a wide range of TV channels with the addition of an electronic programme guide so you can keep on top of your week's viewing.
Multiple HDMI sockets and a PC input makes it easy to connect to other digital entertainment devices. The W3 series even supports USB connectivity for the playback of compatible video, audio and photos.
Witness stunning picture performance and enjoy a breath-taking overall viewing experience with the Toshiba 32W3451DB 32" TV.
Toshiba 32W3451DB W3 Series - 32" LED-backlit LCD TV - HD - for hotel / hospitality
LED-backlit LCD TV - Smart TV
Diagonal Class
32"
Commercial Use
Yes - hotel / hospitality
Matte black bezel with gloss black trim
Resolution
1366 x 768
Display Format
720p
Frame Rate & Enhancement Technology
100 Hz Active Motion Rate
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
Wi-Fi (optional), LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
Edge-lit LED, direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
NTSC, PAL, SECAM
Internet Streaming Services
Netflix, YouTube, BBC iPlayer
Settings Cloning Capability
Speaker System
2 speakers
Stereo Reception System
NICAM
USB
2 ports
Toshiba CT-8035 remote control, 2 AAA batteries
Voltage
AC 230V (50 Hz)
Energy Class
Class A
65 Watt
Power Consumption (On mode)
40 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
58 kWh
74.5 cm x 21.5 cm x 49.8 cm
8.5 kg
Energy Class
Class A
65 Watt
40 W
58 kWh
Diagonal Class
32"
Commercial Use
Series
W3 Series
TV Tuner
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Game mode, hotel mode
Timer Functions
Sleep
Dimensions
With stand
74.5 cm
21.5 cm
49.8 cm
8.5 kg
Enclosure Colour
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
25000:1
Brightness
300 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
10 ms
Display Menu Language
Danish, Hungarian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Bulgarian, Serbian, Romanian, Montenegrin
Comb Filter
3D digital
Colour Temperature Control
Audio Description (AD), Automatic Format Detection (AFD), Digital Noise Reduction (DNR), MPEG Noise Reduction, control panel lockout, Clone Function, Active Backlight Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Slant mold black
Flat Panel Mount Interface
200 x 100 mm
TV Tuner
Analogue TV Tuner
NTSC, PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
Reception System
SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, SECAM-L, PAL-K
NICAM
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
FREEVIEW HD
MPEG Profiles and Levels
MPEG4 AVC/H.264
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43
Teletext
Teletext Memory
1000 pages
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Toshiba CT-8035
Audio System
Digital Audio Format
Dolby Digital Plus output
Speaker System
2 speakers
Output Power / Total
12 Watt
Virtual surround sound, Dolby Digital Plus
Speakers
2 x main channel speaker - 6 Watt
Network & Internet Multimedia
Functionality
WEB browsing
Connector Type
Digital audio output (coaxial) , Headphones , SCART , 2 x USB , VGA input , 2 x HDMI - rear , Composite video / component video input , LAN
2 AAA batteries
Component video adapter , Composite adapter
Power supply
Input Voltage
AC 230V (50 Hz)
0.5 Watt
No signal power off
Dimensions & Weight Details
Panel with stand - 74.5 cm x 21.5 cm x 49.8 cm x 8.5 kg , Panel without stand - 74.5 cm x 10.4 cm x 45.5 cm x 7 kg
Width (Shipping)
91.5 cm
Depth (Shipping)
15.4 cm
Height (Shipping)
58.5 cm
Weight (Shipping)
11 kg
