Toshiba 2TB Stor.E Plus Portable USB 3.0 2.5" Hard Drive Black
Quicklinx: 9G9TWS00 Mfr#: HDTP120EK3CA
Quickly transfer files with SuperSpeed USB 3.0 and store up to 1 TB of data on STOR.E PLUS external drives. Easy to use and backward compatible with USB 2.0, STOR.E PLUS external drives are ready to use with Microsoft Windows with no software installation required.
Toshiba StorE PLUS - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
NTFS formatted
Enclosure Colour
77 mm x 117 mm x 20.6 mm
234 g
2 TB
2.5"
USB 3.0
NTFS formatted
77 mm
117 mm
20.6 mm
234 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Compatible Bay
2.5"
Microsoft Windows Vista / XP / 7 / 8
System Requirements Details
Windows XP/Vista/7/8 - 750 MHz - RAM 256 MB
1 x USB 3.0 cable - external
Enclosure Colour
